will this turbo drain correctly
Old Dec 26, 2005 | 03:59 PM
fmfkid250's Avatar
Default will this turbo drain correctly
see the plug in the oil pan thats where it will be going on
this is on an 04gsxr 750
Old Dec 26, 2005 | 04:04 PM
hondaguyef's Avatar
Default Re: will this turbo drain correctly (fmfkid250)
Yes.
EDIT: Clock the turbo so that the return port is vertical to the ground then use a 45* fitting on both ends of a -10 line. Understand?
Phil
Old Dec 26, 2005 | 04:21 PM
splitime's Avatar
Default Re: will this turbo drain correctly (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Yes.
Phil</TD></TR></TABLE>
Partially true, that plug on the bottom is most likely below the oil level... you'll need to tap the pan higher (above the oil line) for proper drainage.
Old Dec 26, 2005 | 04:30 PM
hondaguyef's Avatar
Default Re: will this turbo drain correctly (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Partially true, that plug on the bottom is most likely below the oil level... you'll need to tap the pan higher (above the oil line) for proper drainage.</TD></TR></TABLE>
Yep, you're right
Old Dec 26, 2005 | 04:37 PM
T.J.'s Avatar
Old Dec 26, 2005 | 05:51 PM
Lmgrcivic's Avatar
Default Re: will this turbo drain correctly (T.J.)
yeah you put it to low its going to have trouble pushing the oil through
Old Dec 26, 2005 | 06:11 PM
Jim Truett's Avatar
Default Re: will this turbo drain correctly (Lmgrcivic)
It is possible to tap the return lower than the level of the oil, and it will work fine only if the oil level in the crankcase is below the outlet of the turbo.
Old Dec 26, 2005 | 06:37 PM
fmfkid250's Avatar
Default Re: will this turbo drain correctly (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">It is possible to tap the return lower than the level of the oil, and it will work fine only if the oil level in the crankcase is below the outlet of the turbo.</TD></TR></TABLE>
yea i am sord of torn on this, i cant really put the return any higher unless i make an entire new oil pan........ the turbo is higher then the oil line so hopefully i will be ok!!
thanks for all the input
Old Dec 26, 2005 | 06:42 PM
coneheadsracing's Avatar
its fine, i have a canton 5 quart pan, and i used a hole they already had in the pan, which was on the very bottom of the pan. Mine drains fine. I was having problems at first with other issues and hooked up a clear tube, and when not running it would fill up the line half way. Soon as i started up the car, it drained perfectly. If in doubt use a clear line to check and see.
Old Dec 26, 2005 | 07:09 PM
Importordomestic's Avatar
Default Re: will this turbo drain correctly (coneheadsracing)
You are INSANE to put a turbo on a bike. but i like it!!!
post vids when you are done of 6th gear throttle wheelies...lol
Old Dec 26, 2005 | 07:18 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
you will be ok with the drain there. also the line doesn't have to be above the oil level, all factory turbo audi/vw's return to the bottom.
also on a Comptech SC kit for S2K that i recently installed, the return plug replaced the drain plug
FeedBack159
Honda CR-V & Element
17
Mar 17, 2014 09:35 PM
"00"R
Jun 21, 2007 10:48 AM
BauleyCivic
Oct 16, 2004 08:08 PM
jEE
Jul 24, 2004 09:04 AM
b18civicek850
Apr 11, 2004 10:00 AM
