Will this be safe?
Old Aug 13, 2002 | 11:48 PM
AllMotorITR's Avatar
New User
Default Will this be safe?
Ok guys, I need to know from you turbo guru's if this is going to be safe to run... I ordered a Drag 3 kit from importparts.com, as well as an Inline Pro Headgasket. I plan to run 6lbs of boost on the street daily. By December, I should have Hondata Stage 2b, injectors, a fuel pump, and an FPR.
My questions are:
Will it be safe to run 6lbs before I get the standalone?
Will I be able to run 10lbs max with the fuel upgrades and hondata with just the headgasket and no other bottom end work?
The gasket is supposed to lower compression to 9.3-4:1...
TIA
Old Aug 14, 2002 | 12:20 AM
rjardy's Avatar
Default Re: Will this be safe? (1 FAST R)
You will be fine with the 6 pounds, and as for the ten, im not sure, i mean i know it could take it but i dont know for how long. I plan on sticking around 8 at the track, ~6 on the street.
Rob
Old Aug 14, 2002 | 06:56 AM
Mase's Avatar
uh i dunno about that inline pro headgasket, but anyways, I ran 8 psi for almost 7 months on my b18b, no problems, then upgraded to hondata and now im runnin 12 psi on stock internals. its all about the tuning
Old Aug 14, 2002 | 09:48 AM
New User
Default Re: Will this be safe? (CDooMe2)
Ok thanks for the responses.
MysteriousGSR
Nov 27, 2002 04:03 PM
Andrew 825SM
Sep 20, 2002 10:27 PM
E Swift
May 15, 2002 08:57 PM
TypeR1558
Feb 7, 2002 05:30 PM
KJ
Oct 5, 2001 10:09 AM
