will i throw a code w/ stock ecu and turbo
Old Mar 20, 2005 | 06:40 PM
Tapen00n's Avatar
Default will i throw a code w/ stock ecu and turbo
will i throw a missing link code, and would my mpg go down or any power loss happen?
Old Mar 20, 2005 | 06:54 PM
2point2's Avatar
Default Re: will i throw a code w/ stock ecu and turbo (Tapen00n)
say again?
Old Mar 20, 2005 | 06:59 PM
Tapen00n's Avatar
Default Re: will i throw a code w/ stock ecu and turbo (2point2)
if i have a turbo with a stock ecu, will it throw a code?
SOHC_MShue's Avatar
what the heck are you asking? You mean a map sensor code? Yes you will if you don't have a missing link or check valves to hide the ecu from seeing boost.
93turbo16's Avatar
um, yes. Unless you hid boost from it. Or have a chipped ecu, running uberdata or crome or hondata.
Old Mar 20, 2005 | 07:04 PM
Tapen00n's Avatar
Default Re: (93turbo16)
what do i have to do to hide boost?
Old Mar 20, 2005 | 07:09 PM
DENCIO's Avatar
Default Re: (Tapen00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n &raquo;</TD></TR><TR><TD CLASS="quote">what do i have to do to hide boost?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote"> have a chipped ecu, running uberdata or crome or hondata.</TD></TR></TABLE>
Old Mar 20, 2005 | 07:13 PM
Tapen00n's Avatar
Default Re: (DENCIO)
theres no way with the stock ecu besides chip or uber?
Old Mar 20, 2005 | 07:19 PM
DENCIO's Avatar
Default Re: will i throw a code w/ stock ecu and turbo (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">have a missing link or check valves to hide the ecu from seeing boost. </TD></TR></TABLE>
Old Mar 20, 2005 | 07:31 PM
93turbo16's Avatar
it pays to read.
Old Mar 20, 2005 | 07:38 PM
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">it pays to read.</TD></TR></TABLE>
Overrated
https://honda-tech.com/zerothread?id=137901
or
uberdata, http://www.ecimulti.com/uberdata is down at the moment.
Modified by Si Shane at 8:58 PM 3/20/2005
Old Mar 20, 2005 | 07:50 PM
Tapen00n's Avatar
Default Re: (Si Shane)
i was told a vafc would do the trick, is this true?
Old Mar 20, 2005 | 08:05 PM
Tapen00n's Avatar
i was looking at hondata chipped p28 ecus, any thoughts?
Old Mar 20, 2005 | 08:17 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n &raquo;</TD></TR><TR><TD CLASS="quote">i was looking at hondata chipped p28 ecus, any thoughts?</TD></TR></TABLE>
i think you need to use the search function.
Old Mar 20, 2005 | 08:18 PM
93turbo16's Avatar
i think you need to use the search function. </TD></TR></TABLE>
me, my friend and I, second that ****.
Old Mar 20, 2005 | 11:01 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">
Overrated
Modified by Si Shane at 8:58 PM 3/20/2005</TD></TR></TABLE>
The hack is still a way of masking boost from the ECU, it is just done electronicaly rather than mechanicaly (check valves, missing link).
I'd just go with uberdata.
Old Mar 20, 2005 | 11:02 PM
Si Shane's Avatar
Default Re: (96-EJ6 B18C)
i use uberdata. But some people arent prepared to tune thier own ****. I know most people using the hack dont have a wideband. Right?
Uberdata aint cheep.
nolicense526
Jun 27, 2007 07:02 PM
slowpokecivic
Feb 20, 2007 04:59 PM
Arch-Angel
Sep 17, 2003 06:41 PM
CiViC SiR
Jul 27, 2003 04:38 PM
Prelude Vtec 23
Jul 20, 2003 06:05 AM
