Will I need a wideband O2
Old Jun 13, 2003 | 03:03 PM
Tyler_Durden's Avatar
Default Will I need a wideband O2
This is probably a n00b question, but I did search and read. I'm going turbo in the next few monthes. I will be running a hondata 200s w/ boost and plan to run about 12 lbs of boost on street and 15 lbs at the track. I plan to have the car dyno tuned. Is there any advantages of having a wideband O2 if I'm already having it tuned with a wideband O2 on the dyno. Thanks for the help.
Old Jun 13, 2003 | 03:07 PM
Flamenco-T's Avatar
Default Re: Will I need a wideband O2 (Tyler_Durden)
if you're just gonna tune it on the dyno, NO, you won't need a wideband.
unless you're planning to do some street tuning, then you can use the wideband on the dyno.
stan
Old Jun 13, 2003 | 06:04 PM
shadowdawn's Avatar
Default Re: Will I need a wideband O2 (Flamenco-T)
Yes, wideband is the BEST and most important gauge your money can buy.
I recommend tech-edge because its VERY cheap and VERY effective for a wideband unit.
Old Jun 13, 2003 | 06:36 PM
Default Re: Will I need a wideband O2 (shadowdawn)
So what advantages are there to having a wideband o2. From what I am aware it is the best way to keep track of my a/f ratio, however if it is tuned well wouldn't I not really need to keep a close track of it. Would having it connected to the hondata have any added advantage over not having the wideband o2? Such as the hondata being able to better read the a/f ratio and adjust if I am running lean or rich.
92integraVTECgsr
Engine Management and Tuning
10
Jul 28, 2011 07:42 AM
uptownrickyv
Jul 2, 2004 11:02 AM
Specialk
Feb 1, 2003 01:30 PM
speshuled619
Mar 22, 2002 09:11 AM
B18CXr
May 17, 2001 03:46 PM
