Will i make 450 hp+
stock bore sleeve gsR
-crowerr rodds
-low compression pistion
-stock head(w/port flow valvetrain)
-itr cams w/ame cam gears
-full race manifold w/ turbonetics t3/t4 62/1
-tial wg 38mm
-greedy type r/s boV
-prw intercooler
- dP /etc...
1000cc
on s200b
-crowerr rodds
-tial wg 38mm
-prw intercooler
- dP /etc...
1000cc
on s200b
stock sleeves, you will need to find a really good tuner
i don't know much about the turbo, might flatten out?
good luck you might want to start looking for another block now
is the turbo capable of 450hp? because if it is then yes you prolly will. how long will those sleeves hold up.... even with a very very good tune i cant see them lasting too long.
if you wanna make that much power why not just have it resleeved. open deck sleeves from darton are only $625 installed.
You might look at a Dart block. Sleeving costs about a $1000, and the Dart block is $2250. You get an entirely new block with a closed deck, bigger water passages, and reinforced main seals. So all in all it costs more, but its a completely upgraded base to start from.
HPfreak
15
Jan 21, 2020 09:53 AM
