will DSM injectors work on...????
Old Jul 18, 2002 | 02:44 PM
BoostedH23a1's Avatar
Default will DSM injectors work on...????
i have a 94 honda prelude si (2.3L non vtec) some 1 told me i should get the injectors off a turbo eclipse and send them to RC to balance and do whatever they do. he said they will probably chard like 100 dollars for that. i can get some injectors for cheap. will they work on mine? i have an injector resistor on my lude so that means i am peak hold right. let me know thanks guys.
peace.
Old Jul 18, 2002 | 03:40 PM
Firedrake's Avatar
Default Re: will DSM injectors work on...???? (BoostedH23a1)
If I told you once........
Brian
Old Jul 18, 2002 | 04:08 PM
ceemarun's Avatar
try using http://www.cruzinperformance.com
as for the fitment and peak/hold stuff, sorry, cant help you there, but i saved you like $60!!
Old Jul 18, 2002 | 05:28 PM
Default Re: will DSM injectors work on...???? (ceemarun)
getting others 2 cents
Old Jul 18, 2002 | 06:19 PM
boomslang's Avatar
They will fit.
Old Jul 18, 2002 | 07:00 PM
Default Re: will DSM injectors work on...???? (Inlinefour)
i know they will fit but whats all this injector resister **** do. my friends civic doenst have one. just accords and preludes from what i gather.
let me know thanks alot.
Old Jul 18, 2002 | 07:13 PM
boomslang's Avatar
Your prelude has a resistor pack stock. You don't need to add a second.
Old Jul 18, 2002 | 07:41 PM
ion_four's Avatar
I think your car also uses low-impedance inectors...just disconnect the wiring from yours and see what the resistance is in the injector with a multimeter...if it's less than 8-10, then you can just plug in the DSM's without a resistor box. If you have more like 14-16, then you'll need the box.
Old Jul 19, 2002 | 09:47 AM
Firedrake's Avatar
Default Re: will DSM injectors work on...???? (ion_four)
"i know they will fit but whats all this injector resister **** do"
Preludes from 92-96 have low-impedance injectors (Peak and Hold) which is why the resistor box is there. Your friend's civic doesn't have a resistor box because his injectors are saturated (high-impedance) just like the 97+ preludes. 1990-1997 DSM turbo injectors (from cars with a manual transmission) are all 450cc Peak and Hold injectors.
Buy the damm injectors already! Do you want me to take pictures of mine in the car so you can see the blue plastic plugs that are common to DSM injectors? We're not lying to you man!
Brian
Old Jul 19, 2002 | 03:35 PM
Default Re: will DSM injectors work on...???? (Firedrake)
ok sounds like im getting them. another question. 7 psi on t3/t4 turbo and 10 at the track. do i have to send them to RC for balance and cleaning?
Old Jul 19, 2002 | 03:50 PM
Blaze45's Avatar
Brrraaaap!
It wold help but you dont have to.
Blaze
Old Jul 19, 2002 | 04:14 PM
Firedrake's Avatar
It is always a good idea to have injectors cleaned, especially if you're trusting them to give you enough fuel not to run lean and kaboom. My worst injector went up 8cc's after cleaning to 448cc's, and it had a dripping spray pattern.....
BRian
Old Jul 20, 2002 | 09:53 AM
firedrake, so i dont take off my resistor box right. leave everything as is. just plug and play right. also on ebay im getting these from a 1g eclipse, he said 450cc injectors that where on an automatic though. what u think?
Old Jul 21, 2002 | 06:26 PM
Firedrake's Avatar
Sorry it took a while to get back to you, we were out racing in AZ at Race Wars
No, you leave everything on the car as it is, they're totally plug and play, just need to tune the fuel once they're in....
As far as I'm aware, the MANUAL tranny DSM turbos came with 450cc injectors....to my knowledge, the AUTOMATIC tranny DSM's (they were all FWD) came with smaller injectors that were 370cc or 350cc or something like that.....so I wouldn't bid on them, or else I'd retract your bid, and if the guy complains remind him that false advertising a product on ebay is fraud......
Brian
Old Jul 21, 2002 | 07:14 PM
ceemarun's Avatar
dude, take it to http://www.cruzinperformance.com for $40.
Old Jul 21, 2002 | 08:38 PM
i reread it it says an upgrade for automatics. i got them for 50 dollars. i dont have any type of fuel tuner or anyhing like AFC, i take it this will be too much fuel?
Old Jul 22, 2002 | 09:32 AM
Firedrake's Avatar
Tell me more about your setup.....what turbo kit or components are you running? I would DEFINATLY get something to tune the fuel with, even a little FPR would be better than nothing......
Brian
Old Jul 22, 2002 | 10:35 AM
apexii's Avatar
Yes and tell him "Quaalude Mike" sent you and you want fedex shipping(inside joke)
Rich is a great guy and gets all of my buisness. If thety don't need cleaning, he will tell you and not charge you for it, unlike *other* places........
Old Jul 22, 2002 | 02:54 PM
Default Re: will DSM injectors work on...???? (apexii)
t3/t4b turbo, those injectors, inline fuel pump, i have a B&M but is a piece of ****!!. go here. http://www.angelfire.com/sc/leenash/index.html ignore those big blue perkins diesel motors i had to put them on there so i could link on ebay.
Old Jul 22, 2002 | 06:21 PM
Firedrake's Avatar
I would definatly get at least an SAFC or preferrably a hondata setup.....frankly with all the stuff you have on there and the $$$ invested, I'd get hondata....
Brian
BlUAc
Jun 29, 2006 12:13 PM
Splat
Nov 7, 2002 10:38 AM
1.8T_EG
Sep 7, 2002 09:30 PM
Prelussion
Aug 22, 2002 02:55 PM
dbman96
Jul 18, 2001 01:53 PM
