will bov work without intercooler
Old Nov 11, 2009 | 08:30 PM
MurtazaDSM's Avatar
Default will bov work without intercooler
I just have charge pipe with a bov on intake side with a filter at the end. I dont hear the bov at all, is it because the intercooler is not hooked up? Also I dont have a downpipe or any exhaust on my turbo, does this affect performance? It looks like this
http://www.youtube.com/watch?v=W5V5KUwGph8
Old Nov 11, 2009 | 08:50 PM
civic_r87111's Avatar
Default Re: will bov work without intercooler
I wouldn't imagine that u would b able to hear the BOV with all that noise, and not having a DP or exhaust won't hurt performance other than the fact of extream engine bay heat.
Old Nov 11, 2009 | 08:53 PM
MurtazaDSM's Avatar
but I can still here my turbo spooling down so im sure I would hear the bov over the noise
Old Nov 11, 2009 | 09:07 PM
Ur BOV poping open or not ur turbo is still going to spool down, if u hear compressor surge then I would b concerned.
Old Nov 11, 2009 | 09:32 PM
MurtazaDSM's Avatar
I know the turbo is always going to spool down, but I was just saying I can hear the spool down over the noise so im sure I would of heard the bov over the noise but I dont
Old Nov 11, 2009 | 11:28 PM
jdm inc's Avatar
you need to hook the intercooler up
Old Nov 12, 2009 | 01:27 AM
redtegra's Avatar
you wont boost if your just revving in neutral.
Old Nov 12, 2009 | 02:38 AM
Turbo1.6's Avatar
+1
Old Nov 12, 2009 | 04:18 AM
kyden's Avatar
how are you supposed to tune it without a downpipe? or are you even gonna have it tuned at all?
Old Nov 12, 2009 | 04:59 AM
D-Rob's Avatar
Mother of God.
Old Nov 12, 2009 | 06:53 AM
hybrdthry911's Avatar
Originally Posted by D-Rob
Mother of God.
lol my thoughts exactly
a BOV on the intake side of the turbocharger(between turbo and filter) will server no purpose. if it is rerouting from the pressure side back into the intake side thats fine but trying to release pressure from the intake side is retarded. you are doing it wrong.
the turbo will never build pressure unless it is sealed from the turbo to the engine so if the intercooler is just disconnected and the charge piping doesnt run directly from the turbo to the throttle body then you are doing it wrong.
yes no downpipe will affect performance, the turbocharger is sucking in engine exhaust, you are doing it wrong.
unless this is what you are going for:
Old Nov 12, 2009 | 09:46 AM
NonovUrbizniz's Avatar
Loved
as mentioned above you're doing it wrong.
BOV goes on the charge piping inbetween the compressor outlet and the intake manifold... there should be no filter anywhere in that line... the filter should only be on the inlet side of the compressor housing.
Also you need a downpipe even if it's just long enough to get the gasses out of the engine bay...
Please don't run your engine until you're done building it.
Old Nov 12, 2009 | 10:14 AM
jdm inc's Avatar
this might help
check the faq threads alot of good info.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
http://www.youtube.com/watch?v=Xp-EV...layer_embedded
Old Nov 12, 2009 | 12:33 PM
RC000E's Avatar
Hahahaha..this is awesome. That's great how you blew your video camera all around with no downpipe.
You gotta learn somewhere, I certainly understand, but if your this far and this confused your moving TOO fast. Slow down, do some reading and be clear on what your doing or your going to waste a whole lot of money.
Get a downpipe on there asap
Find someone local that is reputable and can tune the car (references are a plus)
A bov relieves pressure trapped in the charge piping between the compressor side of the turbo and the throttle body. If you don't have a complete installed system...it ain't gonna work. Furthermore, you shouldn't be allowing the motor to see any pressure above atmospheric untuned. For that matter, if you have larger injectors installed (which appears to be the case by the carbon clouds), you really shouldn't be running it at all. This is the purpose for a basemap (see below).
Are you running this setup as it is right now on a chipped ecu with a basemap? If not, you should be. You live in Cali so you likely have 100 options within 100 miles to help you fix your mess and get you what you need.
You need to get many things straight. At this point you shouldn't be starting the car at all in my opinion. Your setup isn't even finished to the extent you should be revving and posting youtube videos. SLOW DOWN and get a grasp.
Old Nov 12, 2009 | 01:04 PM
Oh snap man, I read ur OP all wrong then.. If u have ur BOV on the intake side of the turbo it won't work. It does need to b between the throttle body and the turbo, u don't have to run an intercooler but not having one will limit u on psi and power. U can run ur charge pipe straight from the turbo to the TB with ur BOV in there somewhere. I must agree with the other ppl on here about tuning and starting and reving the engine too.
Old Nov 12, 2009 | 11:51 PM
jdm inc's Avatar
any pics of the setup btw?
Old Nov 13, 2009 | 08:52 AM
MurtazaDSM's Avatar
sorry guys I know how a turbo works and everything I just had one simple question, will my bov work without my intercooler because it was not set up at the time and yea ill post pics soon
Old Nov 13, 2009 | 11:52 AM
jdm inc's Avatar
you need to have everything hooked up in order for the bov to work and has to be building boost into the engine for it to blow off
Old Nov 13, 2009 | 12:43 PM
Loved
Not to be a dick but if you knew how it worked you wouldn't be asking that question... nor would you wonder if it's ok to run the turbo without a downpipe...
The BOV will ALWAYS work as long as it's plumbed/placed/adjusted correctly...
All it does is vent pressure when the throttle is closed and vacuum is created in the intake manifold but there is still pressure in the charge pipes. It doesn't matter if you have a intercooler or not.
hollaback6
Apr 9, 2003 08:58 PM
b16ahybrid
Nov 17, 2002 05:41 PM
ILOVEGIRLS
Jun 27, 2002 05:41 PM
cann
Jan 16, 2002 05:47 PM
Pritos
Jan 12, 2002 03:12 PM
