Will a b18b oil pan fit a b17a block...
Re: Will a b18b oil pan fit a b17a block... (B18PoweredCivic)
it should...i believe all B-series oil pans are the same bolt pattern. the only difference is the oil pick up units inside.
Re: Will a b18b oil pan fit a b17a block... (93LSivic)
I believe LS and b17/b16 have the same pickups and GSR and ITR are the same. Not completely positive on the B16/7=LS pan though
