Wierd Engine Code after 7psi boost
Old Aug 19, 2003 | 04:17 PM
ProjectEG's Avatar
Default Wierd Engine Code after 7psi boost
Im runnin my car, and in second gear at about 8000 rpms i hit 7psi. My boost isnt spooling until right before i hit vtec. After that, it hits 7 psi around redline. Then, the bad part happens. I throw and engin light, and it idle surges bad, almost like i have a vac leak. I used a check valve setup for temporary use because my missing link broke, but im getting the afc hack soon. Another question, i hated the look of the Spearco lettering, so i flipped the intercooler over, will that matter? I hope someone can help because this is all i have to drive. Thanks a lot
Old Aug 19, 2003 | 04:29 PM
ProjectEG's Avatar
Default Re: Wierd Engine Code after 7psi boost (ProjectEG)
Bump.... Can anyone solve any of my problems?? Any of them at all?
Old Aug 19, 2003 | 04:36 PM
ntegls's Avatar
check dtc first
Old Aug 19, 2003 | 04:37 PM
ProjectEG's Avatar
Default Re: (ntegls)
what the hell is DTC
Old Aug 19, 2003 | 04:45 PM
ProjectEG's Avatar
Default Re: (ProjectEG)
i cant get anymore help here??
Old Aug 19, 2003 | 04:56 PM
sporkcrx's Avatar
You have to give everyone more information. What's the set up?
Old Aug 19, 2003 | 06:00 PM
ekb18c's Avatar
Check the code...
You should be fine with the intercooler flipped around.
Old Aug 20, 2003 | 10:25 AM
ProjectEG's Avatar
Default Re: Wierd Engine Code after 7psi boost (ekb18c)
i have a b16 with a greddy street turbo
Old Aug 20, 2003 | 10:29 AM
boosted_dc2's Avatar
what code is it???? do you have obd1 or 2
gettin it
10
Jan 4, 2008 06:53 AM
BB[6]King
Oct 31, 2006 07:40 PM
JDMTurboCivic11
Apr 16, 2005 04:43 PM
g2_boosted
Dec 5, 2002 05:20 PM
2000blacksi
May 5, 2002 12:08 AM
