Wierd Cel Code
Old Dec 17, 2003 | 04:20 AM
BringIT's Avatar
Default Wierd Cel Code
My check engine came on today, but I'm not sure what the code is. When I jumped the connector it flashed 1 then went solid. Normally, when you get a code it will keep repeating itself, but this time it just remained solid? I sat there for 5 minutes and it didn't change. I turn the key to the off position and back on, and it will blink once again then go solid. Anyone know what this means?
Car runs and idles fine..
1998 JRSC GSR w/ SMC DSM 450s
Old Dec 17, 2003 | 07:45 AM
BringIT's Avatar
Default Re: Wierd Cel Code (BringIT)
anyone?
Old Dec 17, 2003 | 09:24 AM
Del_Slowest's Avatar
take the jumper out and reset ecu. see if it comes back on
Old Dec 17, 2003 | 10:50 AM
fast-rex's Avatar
pull the fuse from the ECU and hazards, off for like 15 seconds and that will reset the ECU. good luck
Old Dec 17, 2003 | 11:53 AM
BringIT's Avatar
Default Re: Wierd Cel Code (Del_Slowest)
Actually, I did that 3 days ago when this happened. I thought it was just a glitch. Now it's back on..
Old Dec 20, 2003 | 08:19 PM
BringIT's Avatar
I'm still getting this code every 2 days or so after resetting the ecu. I was talking to a Honda technician and he thinks it's the SMC or the injector wiring. Since it isn't throwing a valid code, could it have something to do with the wiring? I've checked the wiring of the SMC and it looks good. Could it be a bad ground? The car hesitates a bit but is still drivable. It's hard to tell if it's in limp mode since you can't feel vtec anymore with the jrsc on.
Anyone?
Old Dec 21, 2003 | 12:31 AM
BringIT's Avatar
any help is appreciated..
new_climber
Sep 17, 2009 08:26 AM
y0whuddupb
Dec 29, 2007 07:22 AM
carnifex
Oct 1, 2004 10:28 AM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
brega3
Jun 30, 2003 03:43 PM
