Wideband o2 sensor question.
Old Oct 8, 2004 | 02:54 PM
evilcivilian's Avatar
Default Wideband o2 sensor question.
Question: Is there any specifications of how far to mount the wideband o2 sensor so it reads very accurate readings? Is there any precautions to say like setting it too close to the turbo or the manifold?
Old Oct 8, 2004 | 03:45 PM
bump for answers
Old Oct 8, 2004 | 10:49 PM
bump no answers?
Old Oct 8, 2004 | 11:01 PM
grndcont's Avatar
Default Re: (evilcivilian)
prior to the cat, but at least 18" from the turbine discharge is usualy the norm.
Old Oct 9, 2004 | 12:02 AM
Lucky_Smurf's Avatar
Default Re: (grndcont)
Most people will mount it a bit after the first bend in the downpipe.
Old Oct 9, 2004 | 12:47 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (Lucky_Smurf)
3-5" away from the turbo.
Old Oct 9, 2004 | 06:23 AM
rioninja's Avatar
Default Re: Wideband o2 sensor question. (evilcivilian)
The spec sheet for the Bosch LSU4 sensor, which is what 90% of the wideband
kits come with these days, specify to mount it at least 12", but 18" is optimal.
These sensors get there accuracy by being kept at a precise temperature.
If you have excess heat from the exhaust screwing things up, its harder for the
controller to keep it stable.
Old Oct 9, 2004 | 09:50 AM
thanks for the replys! got the answers i needed
Old Dec 6, 2004 | 05:15 PM
TurboTeG4's Avatar
In the aem instructions it says to mount it 36 inches below exhaust port, which on my drag 3 downpipe would be longer then the downpipe. Where do you mount this on turbocharged cars?
Old Dec 8, 2004 | 12:04 AM
TurboTeG4's Avatar
Default Re: (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">In the aem instructions it says to mount it 36 inches below exhaust port, which on my drag 3 downpipe would be longer then the downpipe. Where do you mount this on turbocharged cars?</TD></TR></TABLE>
Old Dec 13, 2004 | 05:59 PM
TurboTeG4's Avatar
If I mount it on my downpipe next to the stock bung is it ok?
Old Dec 13, 2004 | 06:08 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">The spec sheet for the Bosch LSU4 sensor, which is what 90% of the wideband
controller to keep it stable. </TD></TR></TABLE>
It doesnt matter if you are turbo or NA...this is the recommendation.
DeDonDeRosa
Jul 15, 2010 11:46 AM
InfamousDC2FI
Dec 23, 2005 05:51 AM
ironcheftony
Jul 31, 2004 08:36 AM
shermanyang
Apr 19, 2003 11:24 PM
