Wideband Needed or Not?
Old Aug 24, 2011 | 05:00 PM
Bonestock98GS's Avatar
Default Wideband Needed or Not?
Just a quick question ive had on my mind for a couple days. I was wondering if a wideband is necessary seeing as my tuner says he has plenty of widebands to tune the car with. Do I need a personal wideband? If so which one should I get?
Old Aug 24, 2011 | 05:20 PM
90ZCREX's Avatar
Default Re: Wideband Needed or Not?
You don't have to have one, but its good to have as a safety measure to keep your eye on it. It can help you save your motor if something goes wrong causing you to run lean. The innovate LC1 is a good cheap wideband.
Old Aug 24, 2011 | 05:25 PM
90ZCREX's Avatar
Hey I just noticed your in Columbia, Where are you planning on getting tuned? I'm building a motor right now, should be done in a couple months and gonna need a good tuner.
Old Aug 24, 2011 | 07:23 PM
SovXietday's Avatar
Of all the stupid gauges that people line the interior of their cars with, this is the only one I think is absolutely necessary.
Old Aug 24, 2011 | 07:36 PM
TheShodan's Avatar
Moderator
I Suppose. Been running 12 years Turbo Honda without it. Unless I'm the tuner, I don't need it. All it does is scare people when they let off the throttle while on the highway because it reads 15.2 for a split second. Yes, you need one for actual tuning, but after that, if he's not a good tuner, you'll know something's wrong regardless of what the gauge says. If you can't shut it down fast enough (and no one ever can), its not the most helpful. I look at oil pressure being the most important.
Old Aug 24, 2011 | 09:21 PM
Hey 90ZCREX I am from columbia youve probably seen my hatch sitting in the yard its a yellow hatch. And Shodan thanks man I was contemplating if I needed a wideband all day cause I have had a few friends tell me not to drive the car without a wideband on board
Old Aug 24, 2011 | 09:23 PM
And I am going to Asheville NC to get tuned by J.Davis
Old Aug 25, 2011 | 08:14 AM
Turbo-LS's Avatar
If its turbo put one on it, there cheap enough for added insurance. Shodan is correct you dont nessesarly need it if you have a good tuner but its nice to have to keep an eye on things. I fyou live in a climate thats constantly changing then tune may be a little off when weather changes and could need adjustment which you will see on the wideband reading really rich or lean in boost
95civhb
Engine Management and Tuning
Apr 30, 2009 07:37 PM
b16a3delsol
May 5, 2008 06:49 PM
teddy_dc2
Sep 28, 2007 06:09 AM
kornfan
17
Jul 12, 2005 06:36 AM
typeR 507
Aug 17, 2003 02:13 PM
