wich BOV to use for recirculating system?
Old Dec 3, 2006 | 10:12 AM
wicked2night's Avatar
Default wich BOV to use for recirculating system?
I'd like to have a BOV that gets the job done and can be recirculated back behind the filter of the turbo. What are my options?
Old Dec 3, 2006 | 10:24 AM
EK k kay's Avatar
Default Re: wich BOV to use for recirculating system? (wicked2night)
1g dsm
Old Dec 3, 2006 | 11:59 AM
Default Re: wich BOV to use for recirculating system? (EK k kay)
since i'm not in the states, i'd prefet something aftermarket or online available.
Old Dec 4, 2006 | 04:00 AM
I need more input on wich bov's can be recirculated, preferably some aftermarket ones.
Old Dec 4, 2006 | 04:14 AM
Boilermaker1's Avatar
Anything made for a VW/Audi is recirc'able.
Forge, VF, Samco, etc...
I just used the stock one off a 911 turbo, 35 bucks, does the trick.
Old Dec 4, 2006 | 07:34 AM
Default Re: (Boilermaker1)
Thanks for the ideas, but where did you source one from a 911 turbo? I'd go with that one as well but there ain't really many porsche turbos laying arround on the scrapyard.
Old Dec 4, 2006 | 07:40 AM
komat's Avatar
Default Re: (wicked2night)
most of the greddy type bov are able to.
Old Dec 4, 2006 | 07:44 AM
slow poke's Avatar
Most BOV's can be recirculated. That is, most besides Tial. Greddy, Vortec, Apexi, Blitz, ARC, and many, many others can be recirculated.
Old Dec 4, 2006 | 07:51 AM
DCxMagus's Avatar
the greddy Type S can be recirculated I'm pretty sure you can do it with the RS too if you take off the blue horn thing.
Old Dec 4, 2006 | 09:19 AM
HiProfile's Avatar
Default Re: wich BOV to use for recirculating system? (DCxMagus)
The Type-S has a slight bead around it for dumping (and origianlly had a screw-in accessory), but the genuine one isn't produced anymore. I think there's a blitz and a few others that have a nipple you can bolt on.
As for OEM stuff in Europe, I'd look into the Bosch-style. AFAIK, they were used on either Volvo or Saab. Europe got Evos previous to the Evo8, so hit up a Mitsu dealership about their OEM valve, since they use a MAF system w/recirculating BOV. Evo versions should be for higher performance than say a Volvo version.
Old Dec 4, 2006 | 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked2night &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the ideas, but where did you source one from a 911 turbo? I'd go with that one as well but there ain't really many porsche turbos laying arround on the scrapyard.</TD></TR></TABLE>
I bought it new from an internet parts house. They're available online. I don't remember the whole part number, other than its the Bosch DV and it ends with an 8. There's a couple different bosch DVs, they all have the same black plastic housing, the difference is only the Porsche one has a brass plunger, all the rest are rubber.
Old Dec 4, 2006 | 10:39 AM
Tchleung's Avatar
seriously, a crushed 1G DSM BOV is going to be your best bet.
Old Dec 5, 2006 | 06:03 AM
Default Re: (Tchleung)
Really good info, that why i like HT!
I'll check out the Mitsu stock version, though i skeptic about the BOSCH plastik DV, since they do tend to fail, and the porsche one is supposed to be better but then again VW guys prefered to upgrade to a Forge piece.
In europe there are no DSM's. But thanks guys i now know wich way to look.
Old Dec 5, 2006 | 09:28 AM
Clutch101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked2night &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to have a BOV that gets the job done and can be recirculated back behind the filter of the turbo. What are my options?</TD></TR></TABLE>
http://www.hksusa.com/products/?id=761
Old Dec 5, 2006 | 12:17 PM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked2night &raquo;</TD></TR><TR><TD CLASS="quote">Really good info, that why i like HT!
In europe there are no DSM's. But thanks guys i now know wich way to look.</TD></TR></TABLE>
Get the 1G DSM BOV, they are metal. Not the 2G plastic ones
Old Dec 5, 2006 | 01:00 PM
Default Re: wich BOV to use for recirculating system? (Clutch101)
At first i was happy to see a link for a HKS bov, but then i noticed that somehow you have to choose between the 9PSI or 12+PSI versions. What's that all about?
Old Dec 7, 2006 | 01:32 PM
Clutch101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked2night &raquo;</TD></TR><TR><TD CLASS="quote">At first i was happy to see a link for a HKS bov, but then i noticed that somehow you have to choose between the 9PSI or 12+PSI versions. What's that all about?</TD></TR></TABLE>
Get P/N 17670-006100, it'll do what you need.
Old Dec 7, 2006 | 02:59 PM
Attaus's Avatar
It's spring activated in case you want to use it as a blow off valve. The different options are just for what spring you want.
I'd go with clutch101 on the HKS. I was going to suggest that before he did.
Old Dec 7, 2006 | 10:38 PM
part numbers, that's what i need. Thanks!
Old Dec 8, 2006 | 01:40 AM
Pondus's Avatar
ATP turbo also has what you need, HKS and Greddy BOV's and recirc. adapters : http://www.atpturbo.com/Mercha...e=BOV
rick_rabies
Jun 6, 2009 09:38 AM
raphael
Jan 25, 2007 11:37 AM
b18sihatch
May 16, 2006 11:46 AM
Pnoyej6
May 23, 2005 06:17 PM
underpressure02
Mar 4, 2004 07:39 AM
