why motor keeps blowing??
Old Dec 26, 2005 | 11:53 PM
  #26
miller's Avatar
Default Re: (Dmc1)
nitrous is great, maybe you should put some on your car terry and shoot for 900hp, i will if you do. lol
Old Dec 27, 2005 | 02:38 PM
  #27
1INTEGRA's Avatar
New User
now my ignition timing is stock but my cam timing for my exhast cam is retardeed 5 degrees should i put it back to stock even with a built motor
Old Dec 27, 2005 | 03:26 PM
  #28
SOHC_MShue's Avatar
Default Re: (1INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">now my ignition timing is stock but my cam timing for my exhast cam is retardeed 5 degrees should i put it back to stock even with a built motor</TD></TR></TABLE>
you have a stock engine and retarded your cam timing 5 degrees? That must run like ****
Old Dec 27, 2005 | 03:41 PM
  #29
1INTEGRA's Avatar
New User
Default Re: (SOHC_MShue)
no it runs pretty good did that at the dyno
Old Dec 27, 2005 | 06:50 PM
  #30
JDMs1eeper's Avatar
i used to run a 100 dry shot w/ 440cc injectors on a B20. stock internals. ran it for 2 1/2 years.
whats your AFRs?
Old Dec 27, 2005 | 07:26 PM
  #31
92LSVTEC's Avatar
damn, i sprayed a stock LS auto with a dry 50 shot for two years and never had a problem... i wonder if the fuel jet is too small, or not installed, i have seen it before. good luck man
Old Dec 27, 2005 | 09:30 PM
  #32
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">no it runs pretty good did that at the dyno</TD></TR></TABLE>
you sure you don't mean ignition timing? Did you actually gain power retarding your CAMS 5 degrees?
Old Dec 28, 2005 | 03:31 AM
  #33
1INTEGRA's Avatar
New User
intake cam was advanced 3 degrees and exhaust cam was retardeed 5 degrees
and what is my AFR (ait fuel ratio) and if so how do i find out what mine is besides having that little gauge in my car
Old Dec 28, 2005 | 05:28 AM
  #34
Forrest Gump 9's Avatar
Default Re: why motor keeps blowing?? (1INTEGRA)
Have you check your timing?? You said that your intake is 3* advance, did you check your timing after? On a "STOCK" LS 50 shot shouldn't kill your engine. And I hope to god that you have at least 91 octane in your tank.
Old Dec 28, 2005 | 05:37 AM
  #35
213374U's Avatar
0x5359-0055
Community Builder
Default Re: why motor keeps blowing?? (Turbo9Nut)
1. Run 91 or better fuel and run colder plugs
2. Get some sort of fuel management (SAFC, VAFC, etc.)
3. Get a wideband and TUNE!!!
Old Dec 28, 2005 | 06:11 AM
  #36
b18a1ef9's Avatar
Default Re: (JDMs1eeper)
get your car dyno tuned if you really want to do the 50 shot. im pretty sure you can get hondata with the nitrous option, and just have someone tune it with the necessary fuel.
Old Dec 28, 2005 | 06:13 AM
  #37
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">intake cam was advanced 3 degrees and exhaust cam was retardeed 5 degrees
and what is my AFR (ait fuel ratio) and if so how do i find out what mine is besides having that little gauge in my car</TD></TR></TABLE>
take your car to someone that knows what they are doing.
Old Dec 28, 2005 | 06:21 AM
  #38
downeyballz's Avatar
i have a better solution, you should by some 81.5mm, 9:1 forged pistons from ME.
and get your car tuned, and this wont be happening again.
Old Dec 28, 2005 | 06:51 AM
  #39
213374U's Avatar
0x5359-0055
Community Builder
Default Re: why motor keeps blowing?? (downeyballz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">i have a better solution, you should by some 81.5mm, 9:1 forged pistons from ME.
and get your car tuned, and this wont be happening again.</TD></TR></TABLE>
Nice plug
Old Dec 28, 2005 | 04:25 PM
  #40
1INTEGRA's Avatar
New User
the safc what exhactly does it do i know a little about it but not exactly can i make boost up my fuel pressure in higher rpms and drop it back down in lower rpms cause i don't want to be running like 50 psi of fuel all the time. also i run the highest octane gas in GA which is 93 i think. also does anyone have a built short block for sale.
Old Dec 28, 2005 | 05:50 PM
  #41
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">the safc what exhactly does it do i know a little about it but not exactly can i make boost up my fuel pressure in higher rpms and drop it back down in lower rpms cause i don't want to be running like 50 psi of fuel all the time. also i run the highest octane gas in GA which is 93 i think. also does anyone have a built short block for sale.</TD></TR></TABLE>
With the SAFC you can alter fuel maps for every 500 rpm I believe throughout the length of the powerband. It will simply help you get it to stoich across the board.
DIS-1
Mar 19, 2007 05:36 PM
superman336
Feb 1, 2007 08:19 AM
bottledjdm
Jun 18, 2006 07:29 AM
DPR001
28
Apr 29, 2004 06:54 PM
aandDavidsaid
Dec 21, 2003 10:05 PM
