why does my car shake at idle, also having problems starting?
any help is appreciated, running 550 injectors w/ afc hack rev hard stage 2, idles at like 7-8 hundred... but will shake than calm down, than shake and rattle again
you probably have to lean it down a bit more on the v-afc. and set the fuel pressure regulator to stock pressure, thats alot of fuel pouring into the motor on idle.
If you already did that then probably your spark plugs are starting to get fouled out, you might want t o change them.
hope that helps.
hope that helps.
turbod16y7vtec
Nov 2, 2002 07:43 AM
