Why do spool sooo slow
Old Apr 2, 2003 | 12:07 PM
BorderM3's Avatar
Default Why do spool sooo slow
Any hints?
D16A6
JE 9.5:1 pistons
Eagle ESP H Beam Rods
15 BTDC timing
2" mandrel bent downpipe(i know its small)
1G DSM IC and piping
AFC Hack
Mitsu 14B turbo
I spool 12lbs at like 4000rpm
[Modified by BorderM3, 4:22 PM 4/2/2003]
Old Apr 2, 2003 | 12:17 PM
sutrusu's Avatar
Default Re: Why do spool sooo slow (BorderM3)
what turbo is it?
Old Apr 2, 2003 | 12:21 PM
BorderM3's Avatar
Default Re: Why do spool sooo slow (sutrusu)
my bad man
Mitsubishi 14B
Old Apr 2, 2003 | 01:10 PM
earl's Avatar
can be a sign of too large a turbo for your set-up. Your turbo spools with exhaust HEAT. If you are not making enough heat at lower rpm, it's not gonna spool until it's ready
Old Apr 2, 2003 | 01:14 PM
MiraiZ's Avatar
I thinks its the downpipe more than the turbo size...12psi at 4000rpm isn't bad, but the throughput may not be there to flow more...try a 2.25 or 2.5" pipe...if you want to lose the AC, 3" would be good too
Old Apr 2, 2003 | 02:36 PM
SiRkid's Avatar
Default Re: Why do spool sooo slow (MiraiZ)
a 14b is pretty decently sized for a small guy.
im my bros talon(Stock) ..2.0 L .. id say it really kicks at 3 k.
a d16 with slighly higher comp... 4 k isnt that bad and seem pretty normal.
Old Apr 2, 2003 | 02:38 PM
Infinity_Racer's Avatar
does .5" - .75" REALLY affect it THAT much? not being sarcastic, just wondering cus i dont know
Old Apr 2, 2003 | 02:44 PM
civicudesire's Avatar
dude get yourself a 3" downpipe along with a 3" exhaust and you will spool quicker,or better yet run open downpipe
Old Apr 2, 2003 | 02:52 PM
MiraiZ's Avatar
Default Re: Why do spool sooo slow (Infinity_Racer)
like mentioned above, if the entire exhaust is 2.5 or more, you will see a difference. .5 may not seem like a lot, but if you multiply that by the length of your entire exhaust (about 4 meters long)..it adds up to a lot more exhaust throughput and velocity, which equals a faster spool...
but having said that, 12psi @4000 sound pretty good considering what you got!
[Modified by MiraiZ, 8:53 AM 4/3/2003]
Old Apr 2, 2003 | 03:43 PM
UberTeg's Avatar
run open downpipe and see how fast that **** spools
Old Apr 2, 2003 | 03:48 PM
evoeone's Avatar
Default Re: Why do spool sooo slow (UberTeg)
if you search under my name, you'll see i have a thread about that and an MBC, maybe a boost controler would help, check it out
Old Apr 2, 2003 | 04:25 PM
InTeGrA B18b1's Avatar
Default Re: Why do spool sooo slow (evoeone)
upgrade dp to 2.5 and 2.5 cat to 3.0 and 3 inch exhaust= fast spooling turbo
Old Apr 2, 2003 | 04:31 PM
BoostedSi's Avatar
Default Re: Why do spool sooo slow (InTeGrA B18b1)
downpipe is pretty tiny.
Get a bigger downpipe and exhaust just like the others mentioned.
Old Apr 2, 2003 | 05:18 PM
thrty8street's Avatar
Default Re: Why do spool sooo slow (BoostedSi)
Get an aftermarket lightweight flyweel, some pulley's and larger exhaust piping also get a boost controller to tune your turbo.
Old Apr 2, 2003 | 06:01 PM
NCSTIdriver's Avatar
Default Re: Why do spool sooo slow (thrty8street)
I didn't know boost controllers tuned your turbo
Old Apr 2, 2003 | 07:43 PM
BorderM3's Avatar
I ran it for a while with the same 2" mandrel bent open d/p. I spooled damn near the same with open downpipe believe it or not.
2" even scrapes off teh friggin crossmember there is no room, and i dont have ac
I have a 2" exhaust the whole way back just regular brospeed cat back with test pipe. I am low on money and went that route.
What sucks is, with my stock cam i gotta shift at 7k, that puts me at like 3500 and i bog down. I figure the solution to that is put my stage II na crane cam i had in it before i went turbo back in. I can shift that at 7500 thus putting me in the sweet zone between shifts. I also have the small shitty *** 1g dsm ic piping on it, so putting some bigger piping and getting that heat soaked engine mounted IC out sidemounted would help get some more air back in the engine.
What do you guys think, i should be happy with it right now?
Thanks again!
[Modified by BorderM3, 11:44 PM 4/2/2003]
Topdawgg
May 17, 2007 11:28 AM
non-VTEC
Dec 29, 2004 11:08 PM
I Like Boost
Oct 20, 2003 02:06 PM
stinger
Jan 13, 2003 08:24 PM
AbaZ
Sep 9, 2002 02:36 PM
