Why am I loosing boost after VTEC?
Old Apr 27, 2004 | 07:47 PM
Boost Addict's Avatar
Default Why am I loosing boost after VTEC?
I have a '99 Base Prelude with a Greddy turbo kit. I was messing with the wastegate actuator to get the boost right. I got it right where I want, but according to my boost gauge, it holds about a good 8 psi until VTEC, and then drops off to like 6 psi. I don't know why?! It stays right at 8 lbs through the whole RPM range, but then once I get to about 5500 - 6000 RPM, it drops off to 5 or 6.
There is a hole in my downpipe that I'm getting welded on Thurs, but that wouldn't effect the boost would it? Please let me know if you guys have any ideas, thanks!
Old Apr 27, 2004 | 07:52 PM
redteg1's Avatar
Default Re: Why am I loosing boost after VTEC? (xPRELUDEx)
it may be the problem...fix and let us know watsup
Old Apr 27, 2004 | 08:12 PM
b16ahybrid's Avatar
Default Re: Why am I loosing boost after VTEC? (redteg1)
Whats the pre-set psi for that kit?
Sounds like the turbo my be running out of steam with the higher boost setting.
I Know nothing about the greddy kit so this is just a guess.
I had the same problem n my b16 with a t3. swapped it out for a t3t4 and fixed the problem
Old Apr 27, 2004 | 08:16 PM
Default Re: Why am I loosing boost after VTEC? (b16ahybrid)
It's pre-set at 7 psi, but I've seen people run up to 10 on the same kit.
Old Apr 27, 2004 | 08:20 PM
b16ahybrid's Avatar
hmm ok, And they use the same wastegate actuator to run 10psi?
Old Apr 28, 2004 | 12:16 AM
As far as I know, but I'm sure it should be able hold 8 psi. Any other thoughts?
Old Apr 28, 2004 | 05:32 AM
Civic TSI's Avatar
Look around the air filter piping, maybe there's a restrictor plate like they did for B series. My friend's teg was doing the same until we removed that plate I don't know why they put that there, emissions ??
Old Apr 28, 2004 | 06:21 AM
Derek14's Avatar
Default Re: Why am I loosing boost after VTEC? (Civic TSI)
Would blowby due to the camshaft lift/duration affect this?
Old Apr 28, 2004 | 11:11 PM
Default Re: Why am I loosing boost after VTEC? (Derek14)
TTT
Old Apr 29, 2004 | 12:46 AM
b18crx's Avatar
Hello,
Cam timing and profile can effect boost levels with a turbo or supercharger but more so w/ a turbo as there is back-pressure in the exhaust manifold. When the cam is changed, as wiith V-tech kicking in, the bost will vary. This change in boost does not mean that the turbo or supercharger is not doing it's job. Boost is simply a measure of back-pressure in th intake manifold. If the intake cams have a shorter durationand/or lift then there will be there will be higher manifold pressure and lower pressure in the cylinder. If cams have a longer duration and/or higher lift then there will be a higher pressure in the cylinder and lower manifold pressure or boost. If the engine feels like it is contiuing to make power as the boost drops off w/ v-tech then you are better off. Because if you can produce the same level of power with less boost then you stand less chance of engine damage because of detonation. In some ways boost (measured as manifold back-pressure) is actually the enemy.
HTH,
A K
tyoung
Jul 18, 2008 02:06 AM
BlownBlackSi
Nov 7, 2005 08:28 PM
nic411
Nov 5, 2005 10:19 AM
99lspwr
Mar 18, 2004 02:07 PM
b18cTurbo
Nov 26, 2001 06:47 PM
