Whose car torque-stears really bad when they hit boost??
Old Aug 28, 2002 | 09:20 PM
Adi Radoncic's Avatar
On Fire!
Default Whose car torque-stears really bad when they hit boost??
I now have a really bad problem with my car torque steering whenever I hit boost in the upper rpm's.
If the boost is set to 10psi or 11psi its not really that bad but once I switch to 14psi I can hardly keep the car under control and its just going side to side...
Also is there any way of fixing this besides tuning down the boost?
Tell me about your experiances with this and if it even happens to you guys..
Thanks,
Adi
Old Aug 28, 2002 | 09:28 PM
PureTeg420's Avatar
Default Re: Whose car torque-stears really bad when they hit boost?? (newgsr)
start lifting weights. also... the Z10 radius arms got rid of a lot of my torque steer
Old Aug 28, 2002 | 09:30 PM
SlowTeg's Avatar
I used to have this problem as well... Car would feel scary sometimes on the top end because the front end would try to jump all over the place. As soon as I got new tires (old tires had inside edge eaten) it's alot better. I think the quaife is helping out a little as well. HTH
-Mike
Old Aug 28, 2002 | 09:38 PM
1fstevo's Avatar
New User
Default Re: Whose car torque-stears really bad when they hit boost?? (SlowTeg)
quaife helps alot on torque steer. I used to pull hard right or left I forgot but now it's resolved except minor left right pull alittle. ( not some time left and right. It's left right left right sort of pull, it never go straight).
Old Aug 28, 2002 | 09:41 PM
On Fire!
Default Re: Whose car torque-stears really bad when they hit boost?? (PureTeg420)
Hey thats not a bad Idea.
On the other note my tires only have about 2 thousand miles on them but I don't have lsd or traction bars...
Adi
Old Aug 28, 2002 | 09:43 PM
SlowTeg's Avatar
Well.... you probably already know this but make sure your alignment is good..
-Mike
Old Aug 29, 2002 | 03:16 AM
RGAZ's Avatar
New User
Mine does that, but I found I have a bad upper ball joint and it is causing an alignment problem.
How's your suspension?
Randy
Old Aug 29, 2002 | 09:31 AM
On Fire!
Default Re: Whose car torque-stears really bad when they hit boost?? (RGAZ)
I think that my suspension is in pritty good shape but I definitely have camber issues up front sence both the front wheels toe-out.....
So that might actually be my problem...
Adi
Old Aug 29, 2002 | 09:54 AM
GSRwBOOST's Avatar
It's called an LSD
I get torque steer but it's more in a forward direction.. as each tire grips and the lsd transferrs the power to each wheel...
I can't imagine a turbo car without an LSD....
Old Aug 29, 2002 | 10:31 AM
DIRep972's Avatar
Smarter than you
Default Re: Whose car torque-stears really bad when they hit boost?? (GSRwBOOST)
I want an LSD SOOOOOOOOOOOO BAD! i as well have the Z10 radius arms and they helped torque steer a-ton.
Old Aug 29, 2002 | 11:53 AM
FDragger's Avatar
toe out is the big problem. i kinda have the same problem since i got my skunk2 camber kit. my car just wants to follow every dip in the road and turn into it.
Old Sep 1, 2002 | 09:13 PM
BrokenVtec's Avatar
Default Re: Whose car torque-stears really bad when they hit boost?? (FDragger)
with the z10 radius arms does it affect the feel of the car around turns? i know they help you go strait but how well does it perform around tight corners?
Old Sep 1, 2002 | 09:14 PM
bretx0r's Avatar
Default Re: Whose car torque-stears really bad when they hit boost?? (Boooooooooost)
first gear is a joke when it spikes
Old Sep 1, 2002 | 10:49 PM
93LSivic's Avatar
Default Re: Whose car torque-stears really bad when they hit boost?? (bretx0r)
I get some pretty bad torque steer too. I removed my power steering belt and it helps quite a bit. But when I do a 2nd 3rd 4th gear pull it still gets a little squirrley.
I hope to get an LSD soon to help with this and the main concern, traction!
Old Sep 1, 2002 | 10:57 PM
bottlefedb18c1's Avatar
i went with the traction bars from competiton engenering and it helped alot but i had it on since i got the kit on but i still have tourque steer but it is not that bad
bads2k
Jun 8, 2011 05:32 AM
bigtom388
Nov 21, 2009 12:30 PM
Da K00l Aid Mayun
Dec 17, 2005 08:39 PM
tthame1
Jun 4, 2005 11:01 AM
