Who is using stronger timing belts?
Old Oct 29, 2009 | 09:13 AM
mrx's Avatar
mrx
Default Who is using stronger timing belts?
Hi,
i've took a closer look on my tooth times of my trigger wheel form my standalone ecu today and noticed some oscillations which get worse as higher the rpm does.
The engine runs absolutly fine and the pheonomen is only visible if you look at the tooth times of the trigger wheel during two engine rotations. So you need very high resolution measurement to see the changes.
BUT they are significant... so my question... does anyone of you know about this issue? and what have you done against it?
what's about stronger timing belts, could they halp? or are they realy resuce the oscillations between cam & crankshaft?
Old Oct 29, 2009 | 09:16 AM
EM2Civic's Avatar
Default Re: Who is using stronger timing belts?
Originally Posted by mrx
Hi,
You aren't running a dampener are you?
Old Oct 29, 2009 | 09:21 AM
mrx's Avatar
mrx
You mean a damper on the crankshaft? no i'am not using one... but thats also an idea...
Have you some background informations about this phenomen?
EK FLY
Apr 18, 2005 11:46 AM
valve79
Dec 27, 2004 04:41 PM
RAB
Oct 12, 2004 12:42 PM
99eciVic
Jul 16, 2004 10:22 AM
1 2 NV
Aug 8, 2002 07:01 PM
