who has this?
Old Jun 17, 2005 | 02:33 PM
fanta!'s Avatar
Default who has this?
how many of you guys run the coolant bypass mod on your boosted cars?
Old Jun 17, 2005 | 02:35 PM
EJ1 wilcox's Avatar
Default Re: who has this? (father)
What is the "coolant bypass mod"?
Old Jun 17, 2005 | 03:56 PM
SFWD 1934's Avatar
Default Re: who has this? (EJ1 wilcox)
Most likely talking about when you bypass the coolant line from the throttle body. People say they usually gain HP on a NA car with that mod. It is used to heat the air to aid in cold start up comditions if I understand correctly.
Jason
Old Jun 17, 2005 | 04:33 PM
coupon's Avatar
Default Re: who has this? (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 &raquo;</TD></TR><TR><TD CLASS="quote">Most likely talking about when you bypass the coolant line from the throttle body. People say they usually gain HP on a NA car with that mod. It is used to heat the air to aid in cold start up comditions if I understand correctly.
Jason</TD></TR></TABLE>
what about on FI set ups? would it help?
Old Jun 17, 2005 | 07:03 PM
nfn15037's Avatar
Default Re: who has this? (fifth street)
I don't have coolant going to the FITV or the IACV and it is fine. I didn't notice any difference in how the car runs even in freezing cold weather.
Old Jun 17, 2005 | 07:08 PM
This One's Avatar
Default Re: who has this? (nfn15037)
I used to do that back in the day w/ DSM stuff
who knows what kind of Gains it makes.
After a Long Drive you can Grab the inake manifold and it stays pretty cool.
Old Jun 21, 2005 | 11:30 AM
coupon's Avatar
Default Re: who has this? (This One)
Old Jun 21, 2005 | 11:42 AM
tgreaves's Avatar
I bypassed the coolant line going through my TB and IACV and everything works great.. Only thing I noticed is if your spraying your car and you let off the TB after spraying it will stick shut a little..
aptyk88
20
Sep 27, 2008 06:16 PM
projektcivic
Honda S2000
13
Feb 20, 2008 04:58 AM
si_motor_spt
16
Oct 14, 2007 04:57 PM
SLOAZZ95
Sep 13, 2004 08:41 AM
Stroker
Feb 26, 2003 02:13 PM
