White smoke!! help diagnose
Old Nov 24, 2002 | 08:07 PM
R-1303's Avatar
Default White smoke!! help diagnose
My friends GSR is pushing out white smoke from the exhaust when revving 6-8000Rpm...what could be the cause???
Mods: intank, header, cat back exhaust..
the dealership is giving him the run around saying these mods are the cause but i don't see how at all.
Old Nov 24, 2002 | 08:10 PM
b16ahybrid's Avatar
Default Re: White smoke!! help diagnose (R-1303)
white smoke is usually coolant so maybe his head gasket is leaking.Are you sure that the smoke is white and not just a slight tint of blue?those mods wouldn't cause the engine to smoke....does he have a breather filter?
Old Nov 24, 2002 | 08:14 PM
R-1303's Avatar
Default Re: White smoke!! help diagnose (b16ahybrid)
no breather filter..and coolant level in resvoir tank is the same..and not a tint of blue..but there has been an increasing level of oil consumption.
Old Nov 24, 2002 | 10:02 PM
b16ahybrid's Avatar
From the symptoms it sounds like oil consumption.....but burning oil is gernally blue.......coolant is white and unburned fuel is black...how many miles are on the engine
Old Nov 25, 2002 | 04:49 AM
Hondaconcerto's Avatar
Coolant is the most probable cause even thorugh it is quite strance it only does it between 6000 and 8000 rpm. Might be a small hole some where that only lets some cooland pass with the high pressure generated at that rpm. Dose it continue with the engin properly warmed up and every thing?
Old Nov 25, 2002 | 04:11 PM
R-1303's Avatar
Default Re: White smoke!! help diagnose (Hondaconcerto)
I also thought it was coolant..engine has 35,000 miles on it with an aem cai, dc sports stainless 4-2-1, and tanabe cat back...so head gasket?? would cause it to smoke around 6000-8000Rpm...?
Old Nov 25, 2002 | 04:15 PM
MiraiZ's Avatar
A headgasket with a small leak
Old Nov 25, 2002 | 04:36 PM
DC2R714's Avatar
Default Re: White smoke!! help diagnose (MiraiZ)
Most likely if he is just revving the engine and you can see white smoke it is condensation in the exhaust. I have the N1 and if I rev my engine (not moving) after she is warmed up it will sometimes have white smoke from the condensation of the exhaust. Do a Leakdown test to be sure it isn't the headgasket.
Old Nov 26, 2002 | 06:38 AM
Default Re: White smoke!! help diagnose (DC2R714)
Check if you have any oil in the expansion tank or water on the dipstick, it will tell you strait away if you have a leak some where
dailyekhatch
Aug 15, 2011 06:45 AM
Redprelude98
Nov 25, 2008 10:42 AM
mafia
Aug 17, 2007 05:58 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
R-1303
Nov 26, 2002 01:41 AM
