WHISTLING?? good bad???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">that thing under your hood is spinning 80K +. youd whistle too if you were spinning that fast. </TD></TR></TABLE>
I like that, especially since my welder whistles every damn second of the day...
Depending on the whistle, it could be a small hole boost leak. Have heard them whistle before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec »</TD></TR><TR><TD CLASS="quote">
Depending on the whistle, it could be a small hole boost leak. Have heard them whistle before.</TD></TR></TABLE>
yes its always whistled even after new piping and a new intercooler
What type of BOV? Maybe that needs adjusting, although some only leak/whistle at high vacuum (0% throttle).
I could understand it whistling if you put on a shorter, less restrictive intake/filter or a much bigger exhaust. Otherwise, check for leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playalistic2 »</TD></TR><TR><TD CLASS="quote">I have a t3/t4 turbo b18b and as i'm driving it whistles. Seems like the faster I go the louder. Is this normal?</TD></TR></TABLE>
Sig worthy?
Sig worthy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">
Sig worthy?</TD></TR></TABLE>
i think im gonna put that in there!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">Sig worthy?</TD></TR></TABLE>
you have my permission to use my half.
to make you feel better, the te32e on my t type never shut up. was always screaming. my t3to4b was a little loud on my old setup too. if you don thave a boost leak, you are fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">What type of BOV? Maybe that needs adjusting, although some only leak/whistle at high vacuum (0% throttle).
I could understand it whistling if you put on a shorter, less restrictive intake/filter or a much bigger exhaust. Otherwise, check for leaks.</TD></TR></TABLE>
lol bigger exhaust? it's 3in st8 pipe no cat. Ill make a video 2morrow
LsDecepticon
Jan 14, 2008 02:50 PM
