where to mount hallman boost controller?
Old Oct 23, 2010 | 03:47 PM
Charlie Moua's Avatar
Default where to mount hallman boost controller?
I search but didn't find any pictures or answer.
Seems like a silly question but I like to know where most users mount their hallman boost controller unit & also if you have the cabin-control **** where you mount that.
Pictures would be great, just so i have a clear idea.
Old Oct 23, 2010 | 05:38 PM
Default Re: where to mount hallman boost controller?
Old Oct 23, 2010 | 05:50 PM
blackeg's Avatar
i used to put mine on the drivers side strut tower, just mounted it up with a 10mm bolt to one of the oem bracket holes with one of those insulated clamps.
Old Oct 23, 2010 | 10:17 PM
ShanghaiOC's Avatar
Originally Posted by Charlie Moua
I had mine ziptied to the oil feed line, but you can also mount it by the strut tower. For the control ****, I had that underneath the dash by the fuse box. I know a few people that have placed it on the side of the center console.
Old Oct 24, 2010 | 07:12 AM
Schister66's Avatar
Man U FTW
I did the exact same thing with my Hallman. It fits perfectly inside of those insulated PS clamps
Old Oct 24, 2010 | 07:28 AM
insulated clamps..... can't picture what it would look like... lol
Old Oct 24, 2010 | 10:53 AM
Freshdot's Avatar
Old Oct 24, 2010 | 10:56 AM
Freshdot's Avatar
i ended up not using mine and i'm currently not running a boost controller at all. the hallman was causing my car to want to make well passed 10psi on its lowest setting car would go limp because i'm on stock MAP sensor, the actuator is set to 9.5psi...anyone have any input on this?
Old Oct 24, 2010 | 02:49 PM
nihad's Avatar
mines infront of dizzy on the bolt for the dizzy.. u want it as close to the turbo as possible..
Old Oct 25, 2010 | 06:36 AM
TheShodan's Avatar
Moderator
the "limp" mode will more than likely kick in, no matter what you do, since it is so close to the 11psi limit. IIRC, the stock map is believed to go to 11psi, but in actuallity its closer to 10psi. Time for better map sensor and comparable management if you want to crank it up. Otherwise. 9.5 is about where you're going to stay.
Old Oct 25, 2010 | 06:39 AM
Freshdot's Avatar
does anyone know why the boost wants to spike with the hallman installed at its lowest boost setting on my car though??? reading that it should be as close to the turbo as possible i'm starting to think its because of where i mounted it(pictured above)..i had to use about 3.5 feet of vacuum to get from the actuator to the hallman.
Old Oct 25, 2010 | 02:39 PM
blackeg's Avatar
the controller should have come with a few springs, maybe you have the softest one in there and its just a little too soft.
also, did you get the metal ball bearing one or the ceramic one?
Old Oct 25, 2010 | 03:01 PM
TheShodan's Avatar
Moderator
Not the HBC. Make sure that it is hooked up properly. If its hooked up backwards, it could easily cause a "spike" and kill your engine. If you think you installed it correctly, go back, and check again. ;-)
infumis
Feb 12, 2007 08:29 AM
Mad Cow
Jan 30, 2006 01:42 PM
Luchini
Dec 14, 2005 12:31 PM
Devine
May 26, 2004 02:11 PM
CRX SiR T
Mar 15, 2003 05:03 PM
