Where to find Barb fittings for GE vac log, and T bolt clamps?
i cant seem to find 1/8NPT barbed fittings that will take a decent sized hose, all taketiny *** hose sizes. Where can i find these?
Also im trying to find T-Bolt clamps somwhere, but cant find a decent price on thme , can i buy thme in bulk somwhere or something ?
Re: Where to find Barb fittings for GE vac log, and T bolt clamps? (itr206)
Homedepot some times has decent sized barbs in 1/4" only, but mostly the little ones in 1/8".I have a bunch of the brass fittings you need, they are 1/8" NPT w/ a 1/4" barb rather than the typical 1/8" barb that you'll see that is microscopic. I also have 15 or so T bolt clamps. let me know if you get stuck and need some, I could box them up and send them your way tomorrow.
Re: Where to find Barb fittings for GE vac log, and T bolt clamps? (RenoRacing)
so anybody know where to get cheap T-clamps. Napa wants a fortune for theirs...
Re: Where to find Barb fittings for GE vac log, and T bolt clamps? (IN VTEC)
I got a lot of T-bolts from this guys. So cheap, I stock up on them
http://www.partssystems.com
Re: Where to find Barb fittings for GE vac log, and T bolt clamps? (boostedb20vtec)
what size would you order for 2.5inch piping ? 2 inch piping ?
http://www.partssystems.com/sh...reeze
Make sure you get a size or so bigger for your piping. 2.5" is the largest diameter of the 250's...try size up or measure the OD of your couplers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec »</TD></TR><TR><TD CLASS="quote">I got a lot of T-bolts from this guys. So cheap, I stock up on them
http://www.partssystems.com</TD></TR></TABLE>
Yeah i this place i beleive has the cheapest T bolts Ive seen
I got mine from http://www.vecco.net for $3.79 a piece
Re: (itr206)
t-bolt clamps I got at http://www.mcmaster.com and large 1/8 npt vacuum connectors from http://www.anplumbing.com
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">Ace Hardware!!</TD></TR></TABLE>
the best place for any brass fittings, barbs, or anything else thats npt
Re: (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec »</TD></TR><TR><TD CLASS="quote">If you have 2 1/2 piping, get the 2.50 clamp. if you have 2.00 or 2 1/4 piping get the same size clamp. it's big enough for your piping.</TD></TR></TABLE>
This didnt work for me, thats what i did first and i needed to go back and buy one size larger.
Re: (xenocron)
the 2.5" barely fit over 2.5" piping w/ silicone couplers. They do, but it's a tough one to get on. I have both the 2.5" and the next size up which i think is 2.75" and those work good, slide over easy and they still clamp more than tight enough, plus they work for the throttle body too, where as 2.5" wont.
Re: (booscivic)
ITR,
this is also where I get all my fittings. They have some weird metric stuff too there.
ITR,
