Where does my Air Intake Temp Sensor Go?
1992 Civic Si
1999 b16a2 Engine
Here is a picture of the sensor and the spot I thought it went. But it's closed up on this manifold?
Thanks for the help.
1999 b16a2 Engine
OBD-II B16A2 has it in the intake pipe.
there is 2 holes, but it doesn't look like it is a spot for that sensor?
Can I see some pictures? if anyone has any.
I need this to past Visual Inspection from the Calfornia Smog Ref.
Thanks Guess.
there is no spot in the stock 99 Si intake pipe. ?
Thanks Guess.
Thanks Guess.
Yup, obd2 has it in the intake charge pipe. That sensor you've got is an obd1 sensor that goes in the manifold where its blocked off.
I dont see y u can put that obd1 sensor in the charge pipe.
Thanks guys. I checked out a 99 Si tonight. I see what you guys mean. It's a whole different sensor.
Anyone have a obd-II b16a air intake temp sensor laying around?
if you wanna use that sensor..put it right on the intake mani..the one on the right..you can see the spot where it goes. Its more accurate supposedly
[Modified by SiRkid, 3:51 PM 4/6/2003]
racerjohn
Apr 14, 2007 10:49 PM
Nice_Dc2r
May 26, 2003 03:44 PM
