Where do I plug in the check valves (MAP Sensor)
Old Aug 23, 2002 | 08:36 PM
pelotudo's Avatar
Default Where do I plug in the check valves (MAP Sensor)
Which hose coming out of the MAP sensor do I use for the check valves? Does the bottom one go to the intake mani, and that's where I put them?
jB
Old Aug 23, 2002 | 09:09 PM
internet ay's Avatar
Default Re: Where do I plug in the check valves (PeloTudo)
they go inline on the vaccuum line to the map sensor and its the one in your pic that the bottom white wiring clip of the 2 goes into, that is your map sensor and the vacuum line coming out of the bottom of that is the line where the valves go
Charlie Moua
Apr 13, 2012 08:24 PM
shaggyeg6si
May 15, 2008 07:48 AM
92hybridAccord
May 4, 2004 11:34 AM
