when will it spool
Old Jun 8, 2003 | 10:13 AM
tonesdef's Avatar
Default when will it spool
i'm going to be buying the revhard kit for my SOHC d16. When can i expect the t/3t/4 to start spooling and get full boost.
Old Jun 8, 2003 | 10:14 AM
hatchback19's Avatar
I'm guessing 4k? t3/t4 is fairly large turbo for a 1.6 unless you have some work done to it and need it in the high rpms.
Old Jun 8, 2003 | 10:22 AM
tonesdef's Avatar
Default Re: (hatchback19)
i red line at 8200 so i need it for the high revs. Or i would go with the greddy but that wouldn't carry boost that high
Old Jun 8, 2003 | 10:23 AM
t04s's Avatar
Not really, I had a .48 housing stage 2 wheel on a stock d16z6 like 4 years ago and it spooled like a ************.10 psi at around 3800 rpm.Just make sure you tell them you want the .48 housing.
Old Jun 8, 2003 | 10:30 AM
RuthlessEF-9's Avatar
Default Re: (t04s)
im running a z6 witha t3/to4e with a .63 houseing and i spoolfull 7lbs at 3400
i guess it just depends i know for sure my head is stock cause i bought the motor from a grandma grocery getter
Old Jun 8, 2003 | 11:16 AM
t04s's Avatar
Default Re: (D16z6turbs)
Whoops, I meant 3200.....sorry.
wfocrx
Oct 8, 2007 01:00 PM
pjr710
May 10, 2007 07:12 PM
BOOSTEDCIVICD16
Jan 29, 2004 04:40 PM
bulori
Dec 19, 2002 06:29 AM
enabi
May 8, 2002 05:05 PM
