When things don't fit....
Old Nov 16, 2003 | 11:23 AM
  #26
Johnyquest's Avatar
Default Re: (tegasaurus)
Nobody asked you... what is that 'adapter' made of?
...It's not aluminum, right!?
Old Nov 16, 2003 | 04:14 PM
  #27
Blown90hatcH's Avatar
Default Re: (Johnyquest)
The block is just mild steel. I needed a quick fix for the problem.
Art - the dp was not the issue itself. The turbo hit the block if I faced the inlet to the passenger side. When I turned it around, the dp had about 2 inches before it hit the radiator. I had a couple solutions....first one though....I couldnt find anyone to buy this manifold and I didnt want to cut it. Second solution was to make it work. So I did.
Old Nov 17, 2003 | 03:39 AM
  #28
Default Re: When things don't fit.... (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">Do you plan on using studs with nuts rather than the bolts?
Yeah, those bolts are temp. I couldn't find any studs that late in the day so I went with some bolts that I had at the house. I am gonna dyno this Sat and needed to finish it up for now. I will redo it later.
f90w
Dec 5, 2007 01:07 PM
DA jeshy
Mar 7, 2006 06:22 AM
CarbonCreations
Jun 6, 2005 09:31 PM
FOrSfEd
Aug 4, 2003 06:57 AM
sshaikh01
Jan 24, 2002 01:54 PM
