when do you guys turn on/off your nitrous?
Old Apr 24, 2005 | 11:02 AM
93formula's Avatar
Default when do you guys turn on/off your nitrous?
for the d series guys, what rpm do you turn it on and off at. thinking about using it with my turbo setup because this nitrous kit is dirt cheap in the forsale section. kinda dont want to pass it up really. thinking about turning it on for around 3k and off at 5500rpm.
or am i just being silly, LOL
Old Apr 24, 2005 | 12:09 PM
NXLude's Avatar
never turn it on before 2500 rpms, and run it till redline....
Old Apr 24, 2005 | 08:49 PM
93formula's Avatar
Default Re: (NXLude)
on most domestic applications we dont turn on before 3k, is 2500 safe for the d series?
Old Apr 25, 2005 | 03:36 PM
93formula's Avatar
Default Re: when do you guys turn on/off your nitrous? (93formula)
bump
Old Apr 25, 2005 | 05:23 PM
randbcustoms's Avatar
run the nitrous through a push button coed and a wot switch hold the button and launch when you hit wot it will activate you'll be up in a safe rpm by them and release the button (shutting it off) at around 7k..although off rpm really varies with your compression ratio and boost levels
Old Apr 25, 2005 | 05:55 PM
b16sedan's Avatar
Default Re: when do you guys turn on/off your nitrous? (randbcustoms)
WOT/MSD RPM/Hobbs switch
3300 - 9000, hobbs shut it off at 10 psi. Worked great. Don't even try to **** around with holding down a button, driving, and watching a boost gauge at the same time.
Old Apr 26, 2005 | 10:49 PM
93formula's Avatar
Default Re: when do you guys turn on/off your nitrous? (b16sedan)
im pretty sure id use a window switch. so itll be safe to run with boost guys... i just dont want to blow up the motor after i build it up LOL.
projectDB7
May 18, 2015 11:05 PM
BIG T
Feb 23, 2008 03:16 PM
forced00si
Aug 15, 2004 06:39 PM
speedworks
Aug 14, 2003 09:05 PM
