Whats the worst that could happen?
Guest
Posts: n/a
Whats the worst that could happen when installing turbo? (for a first time installer)
Is it possible to get a CEL CODE at the first time I run with it if everything is properly installed.
Please say all the things that happened when you installed your turbo kit or kits?
[Modified by BOOSTINSI, 10:35 PM 7/2/2002]
The worst thing?? Oil line shooting off, oil light malfunctions, and you weld your pistons to the cylinder walls!
I just had an oil leak, and a exhuast mani gasket leak.
It wont start...it wont boost....you find the seals on your turbo are messed up from the factory. Oils leaks, fuel leaks, bunch of little problems that can really irritate the hell out of you. You shouldn't get a CEL if you have everything installed right. Did you get a missing link?
Worst case scenario, you die.
blown motor or you burn up when a fuel line comes off the fmu and catches on fire... causign the gas tank to explode.. then you die... and they hit your parents up iwth a "death tax"...
Damn, why didn't I think of that. Just think a freak accident could happen. Your turbo blows at 110,000 rpms and somehow a blade makes its way thru the motor and imbeds itsself in your head......
[Modified by legendboy, 5:39 PM 7/2/2002]
The worst?
https://honda-tech.com/zerothread?id=220742
thats the worst i've seen....oil leaking all over the cabin, 1st degree burns..major headaches
-Rage
-Rage
Layziebtnh055
May 25, 2006 02:07 PM
