Whats the most horsepower i can make on 550cc injectors?
i just wanted to know about how much horsepower it takes to max it 550cc's..
Also how much hp will max out 750cc's.
Re: (2redstars)
http://www.sdsefi.com/techffhp.htm
That chart follows what I've seen on 'typical' hondas, which is to take the CC of on injector and multiply it by 0.7. So: 550cc x 0.7 = 385whp (at 100% duty cycle). One thing to note about that chart, its most likely thoretical crank HP, but also assumes your FPR doesn't bump up the fuel pressure (unlike a boosted honda).
The key is to find your target HP, then find the CC size that will accomplish that at ~75% duty cycle. Injectors can have issues over 85%, and that extra % gives you room for boost spikes or weird glitches, or even improvements.
Re: Whats the most horsepower i can make on 550cc injectors? (92redhatch)
I'm assuming the total number of injectors will be four? A single 550cc injector will not support 350whp, and 8 of them should support 700whp... But I am going to guess it is a 4 cylinder motor. I belive 350whp is do able with 4 550cc injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">i just wanted to know about how much horsepower it takes to max it 550cc's..
Also how much hp will max out 750cc's. </TD></TR></TABLE>
fuel pressure, a/f and rpm play a role in that as well. high rpm kill the duty cycle. i say to be concervative 550's for under 300
ya if they all work properly and are high impatence saturated injectors. Do they come with the resistor box if so then ill trade right now.
Re: (92redhatch)
i have a set of 580 precisions with an resistor box and they only have 1300 miles on them. i just recently found out they max out at about 400 whp and im looking for about 480whp
so who was the one wanting to get rid of the 1000cc.
injector experts please enter-injectors sizing for HP goals and fuel pressure and how they are relat
BlueShadow
12-09-2005 11:11 AM
550, 550cc, b16a3, fuel, good, horespower, horse, horsepower, horsespower, hp, injector, injectors, max, power, support
