Whats the average turbo to put on a b18?
Old Sep 19, 2002 | 12:19 PM
integra-modder's Avatar
Default Whats the average turbo to put on a b18?
I was talking to the guy that will be installing my turbo and he said that in his kit, he includes a .47 a/r, 60 trim turbine. a lot of people on HT i hear use something much bigger like the .63 a/r, 60 trim.
what are the pro's/cons of the .47 a/r and .63 a/r turbines?
What do most of the <U>STREET DRIVEN</U>, daily driver b18's have on HT?
Old Sep 19, 2002 | 04:07 PM
Default Re: Whats the average turbo to put on a b18? (integra-modder)
anyone?
just post what you have on your car!
Old Sep 19, 2002 | 04:15 PM
racerxadam's Avatar
i'm pretty sure most people run the .63 a/r turbine or larger. A .48 a/r turbine will limit overall output on a 1.8
Old Sep 19, 2002 | 04:24 PM
redteg1's Avatar
Default Re: Whats the average turbo to put on a b18? (racerxadam)
with the .63 a/r you will make power all the way and pull till redline. i never heard of people using the .43 on a b18. that seems really small
Old Sep 19, 2002 | 04:53 PM
Default Re: Whats the average turbo to put on a b18? (redteg1)
ok, thanks
Old Sep 19, 2002 | 11:44 PM
camp1320.com's Avatar
most kits like RevHard Mfg use a
.57 trim .60 a/r intake side stage 3 .63 a/r exhaust side
the smaller the trim the faster spool up
the smaller the a/r the quicker spool up or is it the other way around.. but anyways
hope this helps
Old Sep 20, 2002 | 11:05 AM
Default Re: Whats the average turbo to put on a b18? (camp1320.com)
the smaller the a/r, the faster itll spool if the trim isnt tooo huge.
the bigger the trim, the more potential air flow your turbo can carry into the engine.
if your a/r is too fast, itll spool too fast, youll get power too fast, and spin when luanching, if its too big you wont get power till 6
when do most of you guys with .63 /ar & 60 mm trim reach full boost?
Old Sep 20, 2002 | 11:13 AM
redteg1's Avatar
around 4k-4.5k rpms
Old Sep 20, 2002 | 11:29 AM
Pelican's Avatar
and with too small a A/R with a larger Disp motor, the Backpressure will be too huge in the upper RPMs. So pressure is built up into the exhaust track and back into the cylinder because it can't flow forward fast enough. AKA "Falling flat on its face"
Old Sep 20, 2002 | 01:34 PM
hmmm... my tuner was like, i suggest the .47 since the .63 will prob not spool until 6 or 6.5
can someone say this is deffinatley false ?
Old Sep 20, 2002 | 01:37 PM
sutrusu's Avatar
go for the .63
Old Sep 20, 2002 | 01:45 PM
Pelican's Avatar
Default Re: Whats the average turbo to put on a b18? (sutrusu)
go for the .63
https://honda-tech.com/zerothread?id=197981
Looks like exactly what you were looking for
Old Sep 20, 2002 | 04:11 PM
Default Re: Whats the average turbo to put on a b18? (Pelican)
thanks
Old Sep 20, 2002 | 04:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
hope this helps
That is what I got with my Rev-hard and it was the perfect turbo for my car on the street. My new turbo is a little laggy, but make up for it on the top end.
art
Terrible One
Jul 12, 2005 09:17 PM
toxicshit
Oct 30, 2003 01:36 PM
B20bTurbo
May 8, 2002 10:11 PM
H23ludedude
Apr 9, 2002 09:57 PM
sgT
Dec 13, 2001 07:37 AM
