What your fuel system setup?
Old Nov 30, 2001 | 08:22 AM
  #26
bigTom's Avatar
Default Re: What's your fuel system setup? (98Psi ITR)
bigger injectors => less fuel pressure ?
I see 700+ sizes, but why. 550 not enough?
u anwsered it urself... 550's not enough... i think for maybe some people it would be fine though
Old Nov 30, 2001 | 10:11 AM
  #27
smoothludey2's Avatar
New User
Default Re: What's your fuel system setup? (ek9t)
coming soon...
Holley 255 lph intank fuel pump
550cc RC injectors (peak and hold)
AEM fuel rail
AEM fpr
Old Nov 30, 2001 | 10:46 AM
  #28
TurboSedan's Avatar
New User
Default Re: What's your fuel system setup? (smoothludey2)
Sup smoothludley2? What do you think of this weather? Crazy huh? I bet we will pay for it one way or another, Michigan is good for that.
Old Nov 30, 2001 | 11:02 AM
  #29
Adi Radoncic's Avatar
On Fire!
Default Re: What's your fuel system setup? (97CivicFerio)
12:1 FMU
255 Wallbro intank
440 rc injectors
[Modified by newgsr, 2:02 PM 11/30/2001]
Old Nov 30, 2001 | 11:07 AM
  #30
GSRacer's Avatar
New User
Default Re: What's your fuel system setup? (newgsr)
12:1 FMU
255 Wallbro intank
440 rc injectors
same here
Old Nov 30, 2001 | 05:40 PM
  #31
DirtyLude's Avatar
Default Re: What's your fuel system setup? (rawdigga)
-10/-12 lines, man, those things are radiator hoses. Those Aeromotive pumps are larger than my Chinese mechanic friend. You guys planning to fuel jumbo jets.
Holy overkill Batman.
Old Nov 30, 2001 | 06:38 PM
  #32
bigTom's Avatar
Default Re: What's your fuel system setup? (DirtyLude)
i dont know if ur talking to me or not... but the aeromotive pro pumps have -12 lines in and out
Old Nov 30, 2001 | 06:49 PM
  #33
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: What's your fuel system setup? (GSRacer)
Vortech Fuel Rail
Vortech Fuel Pressure Regular
Walbro 255 Fuel Pump
50 shot NOS on a Type R
Old Nov 30, 2001 | 08:11 PM
  #34
accordking's Avatar
Default Re: What's your fuel system setup? (RealTypeR)
Here is my old setup when it was in the trunk. -8,-6 lines, Paxton fpr and pump.
http://us.f1.yahoofs.com/users/8b79c....DNW8ACG4mJ2U7
Everything is being mounted in the engine bay with a custom 1 gallon fuel cell.
[Modified by accordking, 9:12 PM 11/30/2001]
[Modified by accordking, 9:15 PM 11/30/2001]
Old Nov 30, 2001 | 08:36 PM
  #35
1's Avatar
Default Re: What's your fuel system setup? (accordking)
What do you think of this fuel set up? AEM FPR and rail, 12:1 FMU, MSD inline, RC 310cc injectors with a T04X turbo.
TIA
Old Nov 30, 2001 | 10:36 PM
  #36
turbopanda's Avatar
Stock main injectors
Stock fuel pressure regulator
Stock in-tank fuel pump
Bosch fuel pump (with secondary fuel reservoir)
4 x B18C additional injectors, installed Direct-Port style (see pic above)
Link Engine Management (the only reason why this setup works)
boosting 18psi on my car daily. No problems.
Old Dec 1, 2001 | 08:34 AM
  #37
TurboInteg95's Avatar
Rawdigga, I was just kidding.
Hey 1, with the 310's and 12:1 disk your car is going to fall on it's face as soon as it hits boost. And you two guys with the 440's, intank pump and 12:1. You need to lower your rise rate, probably to around 5:1
Old Dec 1, 2001 | 10:06 AM
  #38
Turbohatch's Avatar
New User
Default Re: What's your fuel system setup? (TurboInteg95)
370 injectors
v-afc
255 walbro
vortech fmu
Old Dec 1, 2001 | 10:21 AM
  #39
cyan1de's Avatar
Default Re: What's your fuel system setup? (Turbohatch)
no turbo yet but going to run
walbro 255lph intank fuel pump
aem fpr
aem fuel rail
rc 440cc injectors
hondata stage 2b
*EDIT: misspelled "intank" had intake haha
[Modified by cyan1de, 1:04 AM 12/2/2001]
Old Dec 1, 2001 | 12:28 PM
  #40
TurboSedan's Avatar
New User
Default Re: What's your fuel system setup? (cyan1de)
Sounds like the same setup as mine. Excellent choices BTW.
Old Dec 1, 2001 | 01:36 PM
  #41
chri5's Avatar
Default Re: What's your fuel system setup? (VTC_CiViC)
Walbro 255lph pump
RC 440cc injectors
V-AFC
Same Here, with the addition of an AEM FPR.
Old Dec 1, 2001 | 02:08 PM
  #42
1's Avatar
TurboInteg..... please explain why and point out the cheapest component(s) to replace to remedy this situation....TIA!
Old Dec 1, 2001 | 04:42 PM
  #43
1's Avatar
Default Re: What's your fuel system setup? (1)
anyone?
Old Dec 1, 2001 | 05:32 PM
  #44
89turboteg's Avatar
Banned
Im running rc 320cc and a cartech FPR with a inline pump. Its a D16a1 but boosts 12psi no prob with a/f ration at 12.75:1 on the dyno at 12psi. had enough fuel but ran into other problems on the dyno keeping the Hp under 200. Could have been a slipping clutch, but when boost was upped from 10 psi to 12 only gained 5 hp. not sure what else couled cause that. any ideas?
Old Dec 1, 2001 | 07:14 PM
  #45
SiR Kid's Avatar
New User
Default Re: What's your fuel system setup? (mplex2000)
**** sorry, I'm thinking alcohol... alcohol/methanol eats away aluminum over time.... Sorry
As far as I know my sleeves are steel, thank you
Old Dec 1, 2001 | 07:31 PM
  #46
Dr.James's Avatar
Hondata Stage 4
-8 and -6 braided lines under hood, and stainless hard lines under car.
Bosch in tank pump
aeromotive High flow Filter
MSD 1100 CC injectors
Custom Fuel Rail.
Old Dec 1, 2001 | 09:52 PM
  #47
1, all you need to do is buy the calibration disk for about $25, check out the vortech website. The reason it's going to fall on it's face is because of the larger injectors. 12:1 or 10:1 rise ratio is to much with 310's. Try an 8:1
Old Dec 2, 2001 | 06:51 AM
  #48
1's Avatar
What if I put my stock (92 GSR) injectors back in?
Old Dec 2, 2001 | 10:55 AM
  #49
SiR Kid's Avatar
New User
I've got a 6:1 Vortech FMU for sale for anyone interested.. used, but in decent to good shape... Hell, it works. Period
RACING INTEGRATION
Nov 20, 2005 10:05 PM
Mr.Death
Jun 22, 2005 01:12 PM
iBrandon
Feb 17, 2005 02:33 PM
uNF$@#!
Aug 6, 2002 07:45 PM
