what would be a reasonable price for my car?
1998 Acura Integra GSR
Ford mustang gunmetal gray paintjob
shaved door mouldings
shaved front and rear emblems
shaved antenna
Wings West W kit all around
Fiberimages Carbon fiber hood
Sparco Silver hood pins
41k miles on chassis
A/C
cruise control (not installed)
stock GSR wheels quantity 6
17" wheels (haven't gotten them yet)
JDM ITR steering wheel
stock steering wheel
Sparco pedals
DC Sports shift ****
white gauge overlay
pioneer CD deck
pioneer speakers all around
B&M shifter
Energy Suspension shift bushings
Energy suspension motor mounts
Prothane driver side main engine mount
-6an fuel lines to and from gas tank
K&N billet fuel filter
Bosch High Flow externally mounted fuel pump good up to 600 hp
Front, rear, and rear lower suspension bars
VIS coilover system
KYB shocks
Cross drilled front rotors
Axis brake pads
Goodrich SS brake lines
JDM ITR shift boot
JDM ITR clock block off plate
2 60mm Greddy gauge mounts on middle dash
Autometer 2 1/8" electronic fuel pressure phantom gauge
mounted in the location of the cruise control enable button
Autometer boost gauge
Autometer a/f gauge
Autometer dash cowl
Autometer Pencil Shift light system
Del Sol grey stripped front seats
Stock 98 GSR seats
Interrior Complete
go mods:
GEM sleeved 84mm GSR block
0 miles on engine
JE 10.5:1 pistons 84mm
Crower rods
Cometic 84mm head gasket
Portflow 2000 b16a2 head
84mm combustion chamber rework
Full Port and Polish
ITR intake manifold
550cc RC injectors
Portflow Ti retainers
Portflow dual valve springs
ITR exhaust camshaft
GSR intake camshaft
STR race silver cam gears
Climax fuel rail
Paxton FPR
Greddy oil block adapter
JAZ oil vapor catch can
ITR throttle body
Hondata Stage 4B kit
P28 ECU
OBD2 to OBD1 adapter
3bar map sensor
GSR tranny with Kaaz diff
Clutchmasters Aluminum flywheel
Stage 3 clutch
ITR oil pump
GSR oil pan tapped and welded -10AN fitting
MSD digital 6 plus
MSD HVC coil
magnecore spark plug wires
Z10 traction bars
C&R radiator
ITR valve cover
Spoon spark plug wire cover
Spoon Thermostat
Spoon magnetic tranny and engine drain plugs
the car would be sold without the turbo although
the car is prepped for turbo... stock GSR exhaust manifold,
stock exhaust would come with the car
i would include a lot of stock, and turbo parts along
with the car
any thoughts on price?
shaved antenna
A/C
Sparco pedals
white gauge overlay
pioneer CD deck
B&M shifter
VIS coilover system
KYB shocks
Axis brake pads
JDM ITR shift boot
Autometer a/f gauge
Autometer dash cowl
Stock 98 GSR seats
Interrior Complete
go mods:
0 miles on engine
Crower rods
ITR intake manifold
550cc RC injectors
GSR intake camshaft
Climax fuel rail
Paxton FPR
ITR throttle body
P28 ECU
3bar map sensor
Stage 3 clutch
ITR oil pump
MSD digital 6 plus
MSD HVC coil
Z10 traction bars
C&R radiator
ITR valve cover
Spoon Thermostat
with the car
Re: what would be a reasonable price for my car? (TurboT)
18k is steal in that 8k is just motor and 12g is just chassis. I can buy the car and sell the aprts for alot more. put in stock GSR and then sell the car like that.
1 Post
Wow, your car in constantly changing...
Wasnt it Yellow last year? with a Bensons Block and Haltech?
Jesus Man, Don't sell it Either way, 18k is a steal...
Suprdave
PS: Do you still have that Front Tranny Mount?
Suprdave
Re: what would be a reasonable price for my car? (Suprdave)
yeah... always changing
that's my problem...
i really want a 540i 6 speed
it's been my dream car... hehehe
anyways, yep... still have the front mount
you should really drop in a stock gsr and sell the car and then the sell built motor and components piece by piece.
Smarter than you
damn I remember when I was dead set on buying your car.. Must have been August.. Man u have changed alot from then..
New User
Re: what would be a reasonable price for my car? (DIRep972)
you are crazy you know that were do you find all the time for this.
check your mail i need some of your stuff and have a deel for you.
-pat
-pat
Re: what would be a reasonable price for my car? (intekragsr)
i'm about 90% sure that i'm going to sell it for 18k...
might be some minor parts differences between the car that gets sold than the car as listed above....
the car has always gone through changes....
some for the better, some i wish i just stayed the way it was...
anyways, i'm finishing up some last detils on the car...
once that's up... i'll have pics and probably final sale price...
change of plans... i ran into problems with the body shop.
the car is still yellow although panels, moldings, and grommets have been removed from the car. i am going to sell the car yellow. the paint is PPG brilliant yellow. the Wings West body kit does not match the color of the car. The body shop that painted the body kit used the wrong paint code, so the paint is a bit orangy than the yellow of the car.
So, I am getting sick of seeing this car.
I am going to sell it with everything listed on the ad, but without the paint job.
The car is still yellow and will have the built engine and all the other modifications.
first one with $17.5k gets it.
if you want to paint it to whatever color once you own the car, i can leave the car as is so that you can get the complete car painted.
e-mail me if you're interested, i can explain into further detail regarding the car.
take this thing off my hands. i am ready to sign over the title.
thanks
terry
thanks
terry
