Blaast Performance Turbo Kit?
What's up guys? I'm Just wondering if anyone actually owns the kit they make for the B18b. It looks pretty complete and seems to be a good setup for around 250whp on a stock block. I have researched on ht and other places and all I could find is talk about their turbo rebuild service. They want $2600 for the kit which seems like a good price considering it comes with a basemap and almost everything else you need to get going. I know piecing together a kit may still be somewhat cheaper, I'm just exploring options. I would like to keep ac and ps so it looks like a log manifold is a must. I'll be keeping stock block/head for a while so a small, good spooling turbo is what I want, full spool is said to be at about 3000rpm which revving to ~7200 looks like a good powerband. Any insight on this kit or my setup in general is appreciated. I do research a lot and can also turn a wrench so please do not take this as an annoying newbie inquiry but more of open discussion on what setup is good and reliable for a mid two hundred horse b18b, thanks. Here's the link: http://www.blaastperformance.c...kit-b
Only thing I would look into is the wastegate. I've seen the results of cheap wastegates and excellent wastegates. Cheap ones may or may not perform well...seem's to be a hit or miss, and others such as Tial can have astounding results when compared to SSAC stuff, or any cheap one for that matter.
Everything else looks to be promising, fun, and very streetable. Other than the turbo and fuel upgrades, I bet the kit is able to put out 400whp or so.
Regardless, I wouldn't run anything close to wide open w/ the basemap, but I would drive very conservatively to a tuner or dyno shop. I'll place my bets that this kit holds up to it's word. (Assuming the wastegate and manifold are not total garbage.)
They sell rebuilt turbo's not brand new, i buy my turbo from them and it was the old airresearch rebuild not garrett like they say in the add.
I would go and buy piece by piece with better parts for the same money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo18coupe »</TD></TR><TR><TD CLASS="quote">They sell rebuilt turbo's not brand new, i buy my turbo from them and it was the old airresearch rebuild not garrett like they say in the add.
I would go and buy piece by piece with better parts for the same money.</TD></TR></TABLE>of coasre they are rebuilt! Do you honestly think you are gonna get a brand new turbo for under 500.
Also. air research is garret you dummy
airresearch=Garrett
airresearch=Garrett
Curious of your opinions on another decent looking budget kit, the s-fab Stage 1 by 703 Racing: http://www.703racing.com/turbokits.html. I think the cast mani might be better designed and more reliable?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2uned »</TD></TR><TR><TD CLASS="quote">Curious of your opinions on another decent looking budget kit, the s-fab Stage 1 by 703 Racing: http://www.703racing.com/turbokits.html. I think the cast mani might be better designed and more reliable?</TD></TR></TABLE>
TTT, curious on your opinions on this with a few upgrades like big injectors, tial 38mm wg and full tune for mid-high 200whp stock block.
97 Acura Integra
Stock B18b1
*stage 1½ t3/t04b s trim 0.63/0.60 (should spool like a .48 and be capable of 300whp easily)
*JRC 6in FMIC
*2.5in Drag Down pipe(open down pipe)
*Drag Manifold
*DSM 450CC injectors
*plx m300
*crome pro
*obd2->obd1 conversion
*RFL BOV
*Walbro
*Ebay Wastegate.
*Home made Dual stage boost controller.(7psi low, 14 psi high)
ECT ECT....
Shooting for 300whp abour 14psi on a CONSERVATIVE timing retard using crome pro . ill be retarding 1 degree for every lb of boost b/c i haven't fixed the crome hex bug or what ever it is.
Stock B18b1
*JRC 6in FMIC
*Drag Manifold
*plx m300
*crome pro
*RFL BOV
*Walbro
*Ebay Wastegate.
ECT ECT....
Sounds good, I've seen many cases of 300whp+ stock ls's and as they say it seems to be "all in the tune". I'm going to do a compression and leakdown and if those are good I'll be shooting for 300 also. Still wondering if anyone has a 703 racing kit? I crunched the numbers and it seems your paying the same for the kit that it would cost buying part by part which I think is good. Also looking into a vtec but I'm not sure if stock lsvtec is the most reliable for boost. Any other similar setups or ideas would be great.
