what would happen if...
Old May 28, 2003 | 10:59 AM
CD8's Avatar
CD8
Default what would happen if...
i boosted, say 10 psi on my h22a that shows 240 on a compression check all across except for #4 which is lower, at 190. i suspect it to be the rings, i had a small amount of water ingestion. would putting FI on this motor just tear it apart quicker? or could i survive long enough to save for a rebuild of the block?
Old May 28, 2003 | 11:01 AM
soundman's Avatar
I say rebuild then turbo it. Why take the risk of breaking donw somewhere?
Old May 28, 2003 | 11:10 AM
TeStUdO's Avatar
when you do the compression test add some oil to cyl. #4. if the compression raises dramatically then its your rings. if not look other places like valves
Old May 28, 2003 | 01:11 PM
CD8's Avatar
CD8
Default Re: (TeStUdO)
well you see the head was just completely rebuilt about 4k miles ago... so i know its not the valves.
Old May 28, 2003 | 02:28 PM
UNDER PRESSURE's Avatar
Default Re: (CD8)
I would rebuild first cause then you risk more damage in the long run. And I would hate to see your car getting towed out of firebird, yeah i've seen you aroud a couple of times you have clean swap bro.
Old May 28, 2003 | 03:07 PM
CD8's Avatar
CD8
Default Re:
thx...
cryingsuns
Jul 28, 2013 10:21 AM
huge230
Jul 9, 2007 07:13 PM
zigs
Aug 31, 2005 02:12 PM
311
Dec 14, 2002 12:18 PM
lsvtec42
Dec 6, 2001 12:39 PM
