what would be the downside to adding a oil cooler?
Old Dec 6, 2003 | 01:03 PM
90crxzc's Avatar
Default what would be the downside to adding a oil cooler?
I know the positive part would be cooler oil temps but what would be the negative drawbacks by adding a oil cooler to a turbo,ed car, would i lose some oil pressure? oil leaks? the reason i ask is im planning on adding a mocal oil cooler,lines and fittings with thermostat, any comment would be appreciated
Old Dec 6, 2003 | 01:36 PM
Bnjmn's Avatar
Default Re: what would be the downside to adding a oil cooler? (90crxzc)
You will lose a couple psi of oil pressure. The effect of this is negligible.
The only downside is the cost.
Some people don't run a thermostat- it is seen as one more thing to possibly fail.
I kind of agree with this- you can just put a piece of cardboard over the cooler during the colder months and not have to worry about thermostat failure.
For most street/strip driving, an oil cooler is overkill. If you are going to be doing lapping, then it is a good idea.
Ben
KidAccord
Apr 19, 2013 06:58 PM
Speed Infliction
Apr 10, 2006 10:04 AM
DamonBoost
Jun 16, 2002 04:24 PM
itr501
Oct 23, 2001 02:41 PM
