what to use to clean the oil pan?
Old May 14, 2006 | 05:51 PM
BOOSTED_JDM_DB8's Avatar
Default what to use to clean the oil pan?
What to use to clean the oil pan?
Old May 14, 2006 | 05:56 PM
Bailhatch's Avatar
Default Re: what to use to clean the oil pan? (integraXgsr)
drive through puddles really fast!
Old May 14, 2006 | 06:22 PM
boostedblkef's Avatar
Default Re: what to use to clean the oil pan? (Bailhatch)
ummmm degreaser ?
Old May 14, 2006 | 06:43 PM
adseguy's Avatar
Simple green, lots of water and paper towels. Kind of a no brainer
Old May 14, 2006 | 06:46 PM
RCautoworks's Avatar
Default Re: what to use to clean the oil pan? (adseguy)
acetone
Old May 14, 2006 | 06:47 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Simple green, lots of water and paper towels. Kind of a no brainer </TD></TR></TABLE>
I beg to differ, theres A LOT that can go wrong, like breaking your arm with an incorrect wipe stroke
Old May 14, 2006 | 07:06 PM
adseguy's Avatar
Default Re: what to use to clean the oil pan? (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">
I beg to differ, theres A LOT that can go wrong, like breaking your arm with an incorrect wipe stroke </TD></TR></TABLE>
Yeah, I like to use a clockwise stroke...haven't had any problems yet and no carpal tunnel syndrom either....very happy with the results
Old May 14, 2006 | 07:18 PM
SOHCD16y8's Avatar
Yeah, I like to use a clockwise stroke...haven't had any problems yet and no carpal tunnel syndrom either....very happy with the results </TD></TR></TABLE>
Wise words, wise indeed
Old May 14, 2006 | 07:21 PM
HybridKOOP's Avatar
Brake cleaner.
Old May 14, 2006 | 07:39 PM
Default Re: what to use to clean the oil pan? (HybridKOOP)
this is a very helpfull topic im sure tons of people wonder this too
i like the counterclockwise technique myself
Old May 14, 2006 | 07:47 PM
Bailhatch's Avatar
Default Re: what to use to clean the oil pan? (pitbullracer)
ok i apoligize for messing around.
The abslolute best way is to put your oil pan in a raging inferno for 10-15min. let cool. serve.
Old May 15, 2006 | 05:49 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">ok i apoligize for messing around.
The abslolute best way is to put your oil pan in a raging inferno for 10-15min. let cool. serve.</TD></TR></TABLE>
Where can I get this so called "raging inferno." Autozone? NAPA? The only thing I could find on e-bay was Raging inferno level 38 with +29 regeneration for elfs....but I think it was for some kind of world of warcraft car or something. TIA
Old May 15, 2006 | 06:41 AM
project dc2's Avatar
engine brite degreaser .. let it soak and hose it off .. wipe it off then go thru it with brake cleaner
Old May 15, 2006 | 07:01 AM
DannyDeuce's Avatar
Default Re: what to use to clean the oil pan? (project dc2)
I clean mine with a rag on a stick.
DAN
Old May 15, 2006 | 07:48 AM
AspectIndustries's Avatar
Default Re: what to use to clean the oil pan? (DannyDeuce)
vertical wipe is better.
Old May 15, 2006 | 08:13 AM
2MUCHBOOST4U's Avatar
just use an up and down stroke with some K Y and your good
Old May 15, 2006 | 08:41 AM
Default Re: what to use to clean the oil pan? (2MUCHBOOST4U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2MUCHBOOST4U &raquo;</TD></TR><TR><TD CLASS="quote">just use an up and down stroke with some K Y and your good </TD></TR></TABLE>
Yup! Its just that easy. Use protection none the less. Latex Gloves. Those oil base substance can eat your hands.
Old May 15, 2006 | 07:22 PM
Laserjock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXgsr &raquo;</TD></TR><TR><TD CLASS="quote">What to use to clean the oil pan?</TD></TR></TABLE>
geee$h, you're all a bunch'a n00bers! i guess nobody has seen the sand they spread on accidents on the highway! works great - but here's the secret. put a thin layer at the bottom of the pan before sealing it to your block. then next time you gotta clean your pan, you'll have an easier time cause it absorbs all that grease and grime.
Old May 15, 2006 | 10:43 PM
killerB16A's Avatar
Default Re: what to use to clean the oil pan? (Laserjock)
the best degreaser i have found is gunk! by far the best! simple green is crap when it comes to engine grease i have tried it. when you use gunk there is no scrubbing of any sort just spray on and let sit for a minute or so and wash off you can use a hose or a towle if you are worried about a mess.
blackccoupe
Nov 9, 2007 02:25 PM
revlimitcrx
Mar 6, 2007 09:32 AM
integranator
May 20, 2006 09:12 PM
EnKidu
16
Oct 15, 2004 09:59 AM
CleanHatch
18
Mar 15, 2004 08:04 AM
