what turbo for ls/vtec
everything has been prepared,
ported head
endyn aluminum im
darton sleeved
82mm cp pistons
89mm stroker
it will be on a full time race car.
planning to boost up to 35psi
fuel is still undecided if race gas or methanol...
what BW to use? power goals of 700whp.
help. and what tranny too?
ported head
endyn aluminum im
darton sleeved
82mm cp pistons
89mm stroker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillAHonDa »</TD></TR><TR><TD CLASS="quote">the s366 also comes in t3 .70 a/r i belive u should be able to make 700whp</TD></TR></TABLE>
That is correct, and uses the larger 79 trim in the .70A/R that is not used in the .85A/R of that application. Let me know if you need more BW information on that application.
turbosol_16
Jan 3, 2007 09:38 PM
