what turbo for B16?
Old Jul 30, 2008 | 02:53 AM
1990ef's Avatar
New User
Default what turbo for B16?
does anyone have a preference on turbos for the B16? I have a 07/91 civic dx B16 2.0 stroked...manual transmission.
Old Jul 30, 2008 | 08:05 AM
TheShodan's Avatar
Moderator
Default Re: what turbo for B16? (1990ef)
Please be specific with a power goal, purpose and use for the car. Different turbos have different characteristics. Please don't start a "poll" of who uses what. There are an infinite number of combinations. Research online with other people with parts and goals similar to yours and start checking them out. Otherwise, this is a waste of time.
Old Jul 30, 2008 | 08:06 AM
hotrod99's Avatar
your going to have to be more specific on what you want hp wise before anyone is going to be willing to help you out and is this going to be a dd or track car? and more info on the motor also.
Old Jul 30, 2008 | 11:28 AM
1990ef's Avatar
New User
Default Re: what turbo for B16? (hotrod99)
what more info do you need on the motor. it is a 2.0 b16a. i want to be able to run mid 10's. 500 hp is my goal. i don't know what i am making right now, we don't have a dyno where i live. i live in hawaii. probably making around 200hp right now.
Old Jul 30, 2008 | 11:41 AM
hotrod99's Avatar
how are you tuning the car if you dont have a dyno??
Old Jul 30, 2008 | 07:43 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990ef &raquo;</TD></TR><TR><TD CLASS="quote">what more info do you need on the motor. it is a 2.0 b16a. i want to be able to run mid 10's. 500 hp is my goal. i don't know what i am making right now, we don't have a dyno where i live. i live in hawaii. probably making around 200hp right now.</TD></TR></TABLE>
In order for you to be a 2.0 litre b16, you'd have to have at least 89mm stroke, which will not fit in the B16 block. The Best you can get is 1.8 litre with that block due to the deck height. I hope you didn't count on that number from someone telling you it is a 2 litre.
Now. Glad you stated it was 500hp. Is that crank or wheel hp? And yes, it does make a difference. Do you want T3 flange? T4?, Journal bearing, ball-bearing cartridge? Do you know the difference? What chassis are you using? that will determine which sized compressor housing you can use.
Budget?
Never use an E.T to determine need. Go by a horsepower level to the wheels. You do not have to go with an expensive GT-R series turbo to do this power. Is this Drag-racing only? or is this for an additional purpose?
aleEvo
Dec 7, 2010 03:49 AM
redskull1944
Jul 30, 2010 03:46 PM
jaredek
Sep 30, 2008 08:07 PM
boost addicted
Jul 25, 2008 08:50 PM
ImAcracker
May 31, 2006 03:22 AM
