What turbo is this???
Old Nov 6, 2007 | 09:19 PM
ABK's Avatar
ABK
Default What turbo is this???
I just bough a turbo for a pretty good deal. The thing is that I'm not sure what size it is or who makes it. Kid did not really know what size it is, he thinks it's a hybrid 60trim .60/.63 AR. Exhaust housing has precision with .63AR stamped on it, intake side only has .60 on it. Anybody have any ideas what it is, I'm clueless when it comes to turbo sizes and all that ****. Thanks
Old Nov 6, 2007 | 11:11 PM
japan4racing's Avatar
precision turbo makes it check the hot side. you got some good **** there
Old Nov 7, 2007 | 05:09 AM
JDM1civic's Avatar
Default Re: (japan4racing)
oh great, you better put in a cage before the turbo goes in. we don't need you to take out another car! turbo looks good, nice find
Old Nov 7, 2007 | 05:29 AM
MidShipCivic's Avatar
Whats up with that compressor fin in the first picture?
Old Nov 7, 2007 | 05:49 AM
ABK's Avatar
ABK
Default Re: What turbo is this??? (ABK)
it's some paint or some ****, I will clean it off later
Old Nov 7, 2007 | 05:51 AM
agrn93ls's Avatar
I do believe you have a Precision SC44 (should be a 44 im no expert) , which i also have and i love it. Its a Garett turbo with a precision turbine housing.
Very good turbo. If your using it on a honda, depending what kind of manifold (exh) that 90* elbow may have to be removed.
Old Nov 7, 2007 | 05:55 AM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">it's some paint or some ****, I will clean it off later</TD></TR></TABLE>
i wouldn't mess with the paint, its not hurting anything, mine has it too.
your more likely to mess up the fin f'in with the paint.
Old Nov 7, 2007 | 08:20 AM
TIGboy's Avatar
Default Re: What turbo is this??? (agrn93ls)
I do believe that the paint is for balancing...correct me if I'm wrong.
Old Nov 7, 2007 | 08:33 AM
nowtype's Avatar
Default Re: What turbo is this??? (TIGboy)
Take off the wheels and measure them. Then go on majesticturbo.com and find out what turbo you have. No one can look at the housings of a turbo and know the trim of the compressor wheel unless they can find a turbo serial number on it and know the serial numbers. It's a T3/t04e. What trim really doesn't matter in the end, but if you want to know, you have to measure the compressor wheel.
Also if you want to leave the turbo as is, looks like the compressor wheel will have to be on the drivers side. You will also have to use a traditional intercooler setup and not a backdoor setup. You can just cut off the welded on cast elbow, but I don't see any reason you have to unless you want to keep AC.
Old Nov 7, 2007 | 08:54 AM
da_dude's Avatar
Take compressor housing off and measure the trim.
Old Nov 7, 2007 | 01:10 PM
ABK's Avatar
ABK
I just talked to the kid, he said it came with rev hard turbo kit. I also got turbo smart wastegate with it. Anybody know anything about that kit?
Old Nov 7, 2007 | 05:57 PM
agrn93ls's Avatar
yeah mine also came with a revhard kit. its a great turbo for b series vtec motors. but could be useful on any has great 4k+ spool.
Old Nov 7, 2007 | 08:35 PM
ABK's Avatar
ABK
So is it Precision SC44 turbo? I looked at some pix online and it defently looks like it, I know I sound retarded right now and plenty people want to flame me sorry.
If so what trim is it? And how well will it work on stock b18c1 on 6-10psi?
Old Nov 8, 2007 | 07:03 AM
agrn93ls's Avatar
I use it on my GSR at 7.25 (half bar) lbs and it runs great. Very good turbo for that use, actually would be better to use for higher output than that. You aren't even starting to use that turbo at around 6 or so psi. Mine hits full spool right at 4k and pulls hard to 8k and would keep goin but i shut it down there.
Look at precisions web site and you can identify the turbo there.
the part number on mine is a 6031E. your should be the same
Old Nov 8, 2007 | 07:22 AM
turbodano's Avatar
Don't clean the paint off it is there for a reason and if you take it off now you will need to rebalance the wheels.
Old Nov 12, 2007 | 11:11 PM
homicydalboy's Avatar
i think it is the sc63??
slowcrxsib16
Sep 26, 2007 06:00 AM
TmeX05
Sep 25, 2004 05:04 PM
alfee
Jul 29, 2004 07:08 AM
Ivan
Aug 2, 2003 10:45 AM
crxgurlllll
17
Mar 19, 2002 10:26 AM
