what is this thing on the fuel rail?
Old Apr 19, 2005 | 12:11 PM
drift2004's Avatar
Default what is this thing on the fuel rail?
what is this thing on the fuel rail? do i needed for a aftermarket golden eaagle fuel rail?
oh sorry i forgot to add im using steel braided lines. do i still need that?
Modified by drift2004 at 1:24 PM 4/19/2005
Old Apr 19, 2005 | 12:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: what is this thing on the fuel rail? (drift2004)
it is a pulse dampener. and if the GE rail has AN style fittings on the end of it you will not need the dampener. it is used to keep the fuel pump quiet.
JDM_Risa's Avatar
if your referrin to the plastic cover bulky thing its called the muffler baffle has two crush washer one on each side mates the fuel line to the rail
mrbsponge's Avatar
thats the factory banjo fitting, under that plastic cap is a screw, i think its called the fule system bleeder screw, for when yo uneed to remove the rail and remove pressure, you wont need it if you are running a stainless line, but you will need a fittin from the rail to an -AN fitting, GE knows what size they are
Old Apr 19, 2005 | 12:28 PM
rmcdaniels's Avatar
Fuel pulsation damper, prevents pulsations of fuel pressure in the fuel rail.
Old Apr 19, 2005 | 12:30 PM
dustin's Avatar
Default Re: what is this thing on the fuel rail? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Fuel pulsation damper, prevents pulsations of fuel pressure in the fuel rail.</TD></TR></TABLE>
agree
Old Apr 19, 2005 | 12:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: what is this thing on the fuel rail? (dustin)
oh I thought it was a dingohopper.
Old Apr 19, 2005 | 12:38 PM
Muckman's Avatar
Moderator in Chief
Default Re: what is this thing on the fuel rail? (Arturbo)
haha Arts losing his mind again.
Old Apr 19, 2005 | 12:44 PM
drift2004's Avatar
Default Re: what is this thing on the fuel rail? (Muckman)
Great thanks for the quick reply!
Old Apr 19, 2005 | 12:50 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">
agree</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Fuel pulsation damper, prevents pulsations of fuel pressure in the fuel rail.</TD></TR></TABLE>
As do I
Old Apr 19, 2005 | 12:52 PM
drift2004's Avatar
Default Re: what is this thing on the fuel rail? (93turbo16)
ok in the trash it goes then
Old Apr 19, 2005 | 12:54 PM
dustin's Avatar
You can get rid of it... it smooths out the fuel pressure in the rail... supposed to make the car run smoother etc.
ghostriderinnc
Jul 31, 2010 09:38 AM
beginmyhonda
Dec 4, 2009 02:21 PM
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
sohc1200cc
Nov 3, 2006 10:02 AM
