What stock cars used the TD04H turbo's?
I am looking for the banjo bolt for the oil feed line, and wanted to know what stock cars had this turbo on it? I heard the Galant GL4 I believe, and something else? You guys think the dealer might have these? I tried a 91 300ZX TT, but theirs is a M12x1.25 instead of M10x1.25
jB
jB
Re: What stock cars used the TD04H turbo's? (PeloTudo)
Why don't you just buy a 10 x 1.25 banjo bolt from someone like Goodridge? While you're at it, why don't you buy their 10mm to -3AN banjo adaptor and use AN fittings? Anyway, just make sure the bolt is not only 10mm x 1.25 but the proper length so enough threads are left over after going through the banjo. I hope you're using new copper washers. Here is a link to the page listing banjo bolts at Goodridge's website:
http://www.goodridge.net/cat/topframe.html
The part numbers are listed incorrectly, though:
992-02-32 should be 992-03-32 which is a 10x1.25 single banjo bolt w/20mm under hex length
992-02-32L should be 992-03-32L which is a 10x1.25 single banjo bolt w/25mm under hex length
I just ordered the 32L for my TD05H-18G with the -3AN banjo adaptor and 2 copper washers.
ZCHF2
03-12-2003 12:52 PM
