what is this setup worth?(for boost guys)
Old May 29, 2002 | 05:11 PM
singlecam screamer's Avatar
Default what is this setup worth?(for boost guys)
well guys i have an opportunity to buy a turbonetics ball bearing t3/t4 04b,and a drag manifold for my h22,so guys what do you guys this setup is worth,also the turbo has 60 miles on it,please help me out guys
Old May 29, 2002 | 05:42 PM
Default Re: what is this setup worth?(for boost guys) (rudy 94 si)
ttt,come on guys i need your help
Old May 29, 2002 | 06:47 PM
MaxBoost's Avatar
New User
turbo's too small **** that tiny crap. But if you had to buy it i'd say 600. Used is used. no matter how you cut it. Agui (cuttingedgesi) sold his t3/t4e with drag manifold to some kid names Gort for 600 i think.
Old May 29, 2002 | 06:57 PM
intekragsr's Avatar
Default Re: what is this setup worth?(for boost guys) (MaxBoost)
not 600, maybe 500. I got my t3/t04e for 650 brand new at majestic turbo
Old May 29, 2002 | 11:36 PM
inspyral's Avatar
Default Re: what is this setup worth?(for boost guys) (intekragsr)
How much are the ball bearing T3/T4's new?
Old May 30, 2002 | 01:39 PM
Default Re: what is this setup worth?(for boost guys) (inspyral)
thanks guys so what size turbo do you guys recommend,is this turbo really small,because the guy says he bought it new from turbonetics for 1200 bucks,so i don't know what to do
Old May 30, 2002 | 01:47 PM
CovertFI's Avatar
bb turbos are very expensive. i would buy it for 600 and spend a few bucks to upgrade the compressor. like you said he paid 1200 for it new. buy it. i know i would. you could even buy a used t4 with a huge compressor and install it on the bb one.
BUY IT
Old May 30, 2002 | 02:16 PM
Default Re: what is this setup worth?(for boost guys) (CovertFI)
well guys i'm kind of turbo illiterate what is the difference between a ball bearing turbo and one that isn't ball bearing
Old May 30, 2002 | 02:19 PM
GSRwBOOST's Avatar
about two hundred dollars or more.. is the difference.. that and the bb one will spool maybe 500rpm sooner... not a big deal.. but if youcan get one for a good discount.. go for it.. can't hurt. just watch you dont get ripped off..
i dont rembmer reading where your gettign thsi from?
Old May 30, 2002 | 02:21 PM
Default Re: what is this setup worth?(for boost guys) (GSRwBOOST)
well i might get it from my cousin,cause he is in need of money,also how much do you think one of these turbos make power wise
Old May 30, 2002 | 03:22 PM
DA666's Avatar
as much as boost as u run......id say alot of f ing power with the correct components to go along with it......like every aftermarket turbo setup
a smaller unit will make more power at lower boost levels.....i wouldnt put that particular unit on a fully built h22a because u will probbaly make more hp with another bigger unit at the same or higher boost levels
but if ur going the "stay at 7psi" routee like some, it will be fine for u.....if u want to make more than say 350+whp and build on the same block and dont want to buy another turbo in the future....then go wiith a bigger one
Old May 30, 2002 | 04:38 PM
Default Re: what is this setup worth?(for boost guys) (T3T4DA6)
thanks guys,well i plan to put this on for a while,also can i upgrade the compressor wheel to make it better or whatnot
Old May 30, 2002 | 04:47 PM
Etylorcen's Avatar
Only 200 dollar difference? I think the price difference is more like 400-500.
BoOsTeD_eK
Jul 19, 2002 05:04 PM
1996GsrVtec
Jul 5, 2002 03:42 AM
paulzy
Feb 5, 2002 04:08 PM
