what is the proper compression for a 94 ls engine?
Old Jul 10, 2001 | 01:12 AM
Lei Siew Long's Avatar
Default what is the proper compression for a 94 ls engine?
i believe it is 190 or so. but, i just want to make sure. thanks in advance.
Old Jul 10, 2001 | 03:15 AM
Liltrix's Avatar
Default Re: what is the proper compression for a 94 ls engine? (boostedeg6)
9.0:1
Old Jul 10, 2001 | 08:22 AM
TurboInteg95's Avatar
Default Re: what is the proper compression for a 94 ls engine? (Liltrix)
it's actually 9.2:1. you should be getting compression numbers around 185 or so if it's in pretty good condition. If it's brand new you should be getting somewhere around 210.
Old Jul 10, 2001 | 11:54 PM
Default Re: what is the proper compression for a 94 ls engine? (TurboInteg95)
how are these numbers:
cylinder <U></U> compression <U></U>
1 180
2 180
3 165
4 180
same numbers on the second test. how is the cylinder #3? is that bad?
[Modified by boostedeg6, 8:55 AM 7/11/2001]
spoonfed95
May 20, 2004 04:39 PM
wutangben
Jun 2, 2003 06:21 PM
Phat Corolla
Aug 13, 2002 03:50 PM
Jamison
Feb 11, 2002 08:51 PM
Lei Siew Long
Jul 13, 2001 06:28 AM
