how are these numbers after a compression check for my 94 ls engine?
cylinder compression
1 180
2 180
3 165
4 180
i did a second test with the same results. is #3 bad? how much should each cylinder be off by max. thanks in advance
1 180
2 180
3 165
4 180
Re: how are these numbers after a compression check for my 94 ls engine? (boostedeg6)
Not to bad, #3 is a little low but not out of spec. i tested mine after my timing belt broke adn i got 182-190 across teh board with 120+k miles.
Lei Siew Long
07-10-2001 11:54 PM
