What Piping for Downpipe??
Old Aug 3, 2003 | 08:22 PM
BuddyLee's Avatar
Default What Piping for Downpipe??
What piping(bends, etc) do i need for a downpipe on my ls integra?? Also, what metal do you all recommend. do they sell what i need at mcmasters, for instance?
Old Aug 3, 2003 | 08:24 PM
Flamenco-T's Avatar
Default Re: What Piping for Downpipe?? (BuddyLee)
what kind of manifold do you have ? different manifold have different ways to route the DP. Most revhard or Drag, you can get 2 U-bends and it will be plenty enough to get the right angle and etc
stan
Old Aug 3, 2003 | 08:30 PM
BuddyLee's Avatar
Default Re: What Piping for Downpipe?? (Flamenco-T)
cool thats what i was hoping to hear. Could i use the stainless steel u bends, or whatever those are, from jcwhitney, or would that not suffice. Im using a custom log manifold, with a 14b
Old Aug 3, 2003 | 09:16 PM
BuddyLee's Avatar
its 16 gauge, is that thick enough??
Old Aug 4, 2003 | 01:09 AM
Full-Race Javier's Avatar
u can use either stainless of mild steel...i prefer stainless, but its a little more $. yes, 16ga is thick enough and try to get the tighest radius possible bend if ur short on space.
Old Aug 4, 2003 | 01:18 AM
Blueprint's Avatar
How about aluminized steel, heard that it prevents it from rusting. That is if you cant afford a SS DP. what manifold are you using.? I would go with the Stainess steel like Full Race i think they come with a flex pipe. If your looking for budget try Camp1320.com he has 2.5 inch mandrel bent one peice DP.
Old Aug 4, 2003 | 03:32 PM
BuddyLee's Avatar
Default Re: What Piping for Downpipe?? (Blueprint)
how much?
Old Aug 4, 2003 | 04:55 PM
93LSivic's Avatar
FYI, I have a Maxrev 4 bolt ss 2.5" dp for sale. You will need to use a maxrev manifold though.
Oh. You can use any of the metals you asked about there, it comes down to having it welded. Be sure to use the tightest bends possible---usually a u bend will have a tighter radius then the 90 bends.
garados
Welding / Fabrication
Nov 29, 2009 02:33 PM
soon2beB00stedSOL
Feb 14, 2006 10:31 PM
integranator
Dec 22, 2004 03:45 PM
hatchattak
Nov 18, 2003 06:29 PM
