what oil restrictor to use??
Old May 8, 2010 | 09:38 PM
092eg6's Avatar
Default what oil restrictor to use??
got a egay t70 turbocharger, wanting to kno what oil restrictor to use so the cheap seals wont blow inside the egay turbo?? lmk thanks
Old May 9, 2010 | 01:11 PM
092eg6's Avatar
Default Re: what oil restrictor to use??
bump
Old May 9, 2010 | 04:11 PM
gizzmo222's Avatar
-3 oil reticter. They are usually 1/8" NPT (Nation Pipe Thread) and you could pick that up at your local AA or online like full-race.com or anywhere like that.
Old May 9, 2010 | 07:17 PM
Turbo-LS's Avatar
Function7 regulator for oil inlet on turbo. they make a -3 and -4. either one will work
Old May 9, 2010 | 10:21 PM
092eg6's Avatar
wel i ran accross this on egay, http://cgi.ebay.com/Turbo-Oil-Feed-D...item1c11e429cd
says it got a 1/8" Adapter NPT male fitting that goes to the block and one- 4AN male fitting buitl on flange.(made out of Grade 7075 Alum).
will this work?? also says its for a t70 turbo too.
Old May 9, 2010 | 10:38 PM
092eg6's Avatar
anyhow it doesent tell how big the hole is on the restrictor plate. i think i saw somewhere on here that journal bearing turbo uses a .065" oil restrictor hole?!?
Old May 10, 2010 | 05:28 PM
092eg6's Avatar
bump lmk guys
Old May 11, 2010 | 08:21 AM
Function7's Avatar
Warning -- that's a counterfeit Function7 inlet flange in that kit. It's made of cheaply cast aluminum (no that isn't 7075) and have a high failure rate due to this weakness.
We've had a lot of people send those broken flanges back to us and we can't do anything to help them since they are not made by us.
More info here:
http://function7.com/warning
-A
Old May 11, 2010 | 08:22 AM
Function7's Avatar
That's around the correct size restrictor for oil pressures found in Honda engines.
-A
Old May 11, 2010 | 08:24 AM
Function7's Avatar
We usually recommend -3AN unregulated and -4AN regulated.
-A
Old May 11, 2010 | 08:50 AM
b16racereg6's Avatar
i just learned something thanks for posting that up about the knock off's
SpoolnByYou
Feb 14, 2006 05:31 PM
Discosteak
Jul 3, 2004 06:30 AM
T3T495GSR
Dec 12, 2002 10:44 AM
Ri5e
Jun 20, 2002 10:41 AM
Ri5e
May 1, 2002 05:08 AM
