What oil do you use?
Old Aug 23, 2004 | 10:46 AM
import-tooner's Avatar
Default What oil do you use?
What weight and brand of oil do you use on your turbo'd hondas?
Old Aug 23, 2004 | 10:53 AM
Sinner's Avatar
I used to use mobile 1 when I had money, now that I'm broke I use castrol syn blend.
Nick
Old Aug 23, 2004 | 10:56 AM
95GSRTT
Guest
Posts: n/a
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">I used to use mobile 1 when I had money, now that I'm broke I use castrol syn blend.
i use 5w 30 usually but sometimes 10w30. I think im gonna bump it up to a higher weight though.
Old Aug 23, 2004 | 11:16 AM
aznballer's Avatar
10w-30 valvoline high milage oil
Old Aug 23, 2004 | 11:28 AM
toolowsol's Avatar
Default Re: (aznballer)
I just switched from 5w-30 to 15w-50 and i like it much better, I don't burn near as much and my oil pressure stays higher at idle, (previously 19, now 24psi)
Old Aug 23, 2004 | 11:48 AM
Chris F's Avatar
Default Re: (toolowsol)
I switched to Canola oil recently, trying to cut down on the saturated fat.
and I run Mobil1 15w50 in my car.
Old Aug 23, 2004 | 11:49 AM
1Bar GSR's Avatar
Default Re: (ccfries)
I run castrol 10w-40
Old Aug 23, 2004 | 11:51 AM
FOrSfEd's Avatar
Default Re: (1Bar GSR)
royal purple 10w30 for me
Old Aug 23, 2004 | 12:19 PM
blackeg's Avatar
Default Re: (FOrSfEd)
was also running castrol gtx 10-40
Old Aug 23, 2004 | 12:32 PM
Maverik4k's Avatar
Default Re: (blackeg)
mobil 1 syn 10w-30
Old Aug 23, 2004 | 12:51 PM
1boostedcivic's Avatar
Default Re: (Maverik4k)
Mobil 1 synthetic 15w30
Old Aug 23, 2004 | 12:58 PM
Si[R]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maverik4k &raquo;</TD></TR><TR><TD CLASS="quote">mobil 1 syn 10w-30</TD></TR></TABLE>
Old Aug 23, 2004 | 01:00 PM
boosted_dc2's Avatar
Default Re: (Si[R])
mobil non-syn 10w-40.
Landon
Old Aug 23, 2004 | 01:06 PM
Charles B.'s Avatar
Old Aug 23, 2004 | 01:10 PM
ms1motorsports's Avatar
Default Re: What oil do you use? (import-tooner)
Kendall 15-50 with a quart of Lucas oil stabilizer. Works great to keep the walls lubricated on cold starts.
Old Aug 23, 2004 | 01:25 PM
USDM 4G VTEC's Avatar
Mazola corn oil for me
Valvoline Syn Blend 10w-30 for my engine
Old Aug 23, 2004 | 02:11 PM
RACEPAK's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">was also running castrol gtx 10-40</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">I run castrol 10w-40</TD></TR></TABLE>
how often do you change oil with the castrol?
Old Aug 23, 2004 | 04:23 PM
Default Re: (RACEPAK)
Here is what I'm wondering. With the oil runing through the turbo, it would probably break down sooner becuase it is so hot. With a synthetic it would help to keep the oil from breaking down at the high temperature and also help lube the motor. I just can't justify spending the money on synthetic oil. Also, I'm running valvoline 10w-30 right now and my car doesn't smoke until I start boosting. Would a higher weight oil help take care of that?
Old Aug 23, 2004 | 04:38 PM
1Bar GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">
how often do you change oil with the castrol?</TD></TR></TABLE>
I changed it every 2000 miles on the dot a little earlier if I dont think Ill be able to change it at 2000 I dont let it go any over!
Old Aug 23, 2004 | 04:40 PM
HXMan's Avatar
Castrol Syntec...5w40....its the good **** made in belgium!
Old Aug 23, 2004 | 05:30 PM
TheShodan's Avatar
Moderator
Default Re: (HXMan)
Me--- Castrol SYNTEC 10w-30
My brother --- AMSOIL 5w-30
My wife -- Mobil 1 tri-synthetic - 5w-30
Old Aug 23, 2004 | 07:04 PM
djfob's Avatar
Mobil 1 10-30
Old Aug 23, 2004 | 07:21 PM
Cyphear's Avatar
My friend did an oil analysis in his auto-tech college. He found that castrol (non-synthetic) was actually one of the worst, and mobile 1 and amsoil were good, as expected (i dont think they tested royal purple). Suprrisingly Super tech (the $4.17 5 gallon walmart special) is one of the better oils. Basically as he said it the oils that advertise the most turned out to be the worst.
oh, and i run mobile 1 except for currently because i got a motor with bad oil rings (it was like that when i bought it) from a local shop so I use supertech.
Heres another resource if you'd like to read details http://www.bobistheoilguy.com
Modified by Cyphear at 8:24 PM 8/25/2004
Old Aug 24, 2004 | 12:44 PM
turbodan4's Avatar
I started with 15w-50 mobil 1 changed to 10w-30 and oil turned to water almost burned up quick and i blew the seals on my turbo have to rebuild turbo now switched back to 15w-50 smoother operation
Old Aug 24, 2004 | 01:13 PM
xrunner86x's Avatar
Mobil1 10W-30
