What numbers should i be looking for ?
Old Feb 18, 2006 | 09:15 AM
BLKEG6T's Avatar
Default What numbers should i be looking for ?
running jdm b16a with complete type r head, mani and tb. good compression 210 across. brand new headgasket and studs just oem though when i swapped head(wasn't planning on boosting). runnning t3/t4 exh.63 comp .52. running piggy back, with dsm 440's. will me dyno tuned for 8psi. what numbers should i be looking for ? i was thinking 250/190 ????
Old Feb 18, 2006 | 09:33 AM
Hybrid96EK's Avatar
Default Re: What numbers should i be looking for ? (BLKEG6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKEG6T &raquo;</TD></TR><TR><TD CLASS="quote">running jdm b16a with complete type r head, mani and tb. good compression 210 across. brand new headgasket and studs just oem though when i swapped head(wasn't planning on boosting). runnning t3/t4 exh.63 comp .52. running piggy back, with dsm 440's. will me dyno tuned for 8psi. what numbers should i be looking for ? i was thinking 250/190 ????</TD></TR></TABLE>
I think your numbers are a touch high, but maybe.. I think for sure your torque numbers are WAY off.
Old Feb 18, 2006 | 09:47 AM
komat's Avatar
Default Re: What numbers should i be looking for ? (Hybrid93Eg)
with a complete stock b16a , log manifold. and t3/t04e 57trim .63
i only made 210-220hp/135tq at 5psi
Old Feb 18, 2006 | 12:31 PM
urbansi's Avatar
Default Re: What numbers should i be looking for ? (komat)
I made 215hp and 162tq on an 18g with a street tune on Uberdata and 310cc injectors.
Your tq expectations seem kinda high, i think you having been reading too much about LS motors with the number you came up with
Old Feb 18, 2006 | 12:43 PM
beerbongskickass's Avatar
Default Re: What numbers should i be looking for ? (urbansi)
I would expect a minimum of 300whp out of any b-series setup. Your goals will be no problem at all, just keep turning the boost up until you get to 250whp.
Old Feb 18, 2006 | 01:19 PM
Hybrid96EK's Avatar
Default Re: What numbers should i be looking for ? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I would expect a minimum of 300whp out of any b-series setup. Your goals will be no problem at all, just keep turning the boost up until you get to 250whp.</TD></TR></TABLE>
I was commenting on his predictions at *8* psi. Anyone can keep cranking up the boost until they see the numbers they want, that wasn't my point. At 8psi, asking 200wtq from a B16 is asking a LOT.
Old Feb 18, 2006 | 01:41 PM
I know, but people need to realize what "psi" you run doesn't mean anything. It's pointless talking about how much boost you run. Example, you could have one car making 400whp off 15psi, but another car making 300whp on 25psi. If this guys wants 250whp or 190wtq, he should turn the boost up until he gets there. His motor is defintely capable of his power/torque goals.
Old Feb 18, 2006 | 01:52 PM
cobra2326's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">I was commenting on his predictions at *8* psi. Anyone can keep cranking up the boost until they see the numbers they want, that wasn't my point. At 8psi, asking 200wtq from a B16 is asking a LOT.</TD></TR></TABLE>
I disagree, look at this setup w/ a STRAIGHT t3 at 6psi, 2.25" dp and exhaust (225whp, 184tq).:
http://forums.evans-tuning.com...=2718
Beerbongskickass is one of the more intelligent do-it-yourself kids on here and he's right. Numbers vary from engine to engine, tune it right, and you'll easily make 250/180.
Old Feb 18, 2006 | 02:00 PM
Hybrid96EK's Avatar
Default Re: What numbers should i be looking for ? (cobra2326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 &raquo;</TD></TR><TR><TD CLASS="quote">
Beerbongskickass is one of the more intelligent do-it-yourself kids on here and he's right. Numbers vary from engine to engine, tune it right, and you'll easily make 250/180.</TD></TR></TABLE>
congratulations. not only was that LESS then 175tq, it was also FLYWHEEL ratings. Thanks for helping me prove my point.
Old Feb 18, 2006 | 04:29 PM
congratulations. not only was that LESS then 175tq, it was also FLYWHEEL ratings. Thanks for helping me prove my point.</TD></TR></TABLE>
No, you are still incorrect. That was 225/184 at the wheels.
Old Feb 18, 2006 | 04:53 PM
Hybrid96EK's Avatar
No, you are still incorrect. That was 225/184 at the wheels.</TD></TR></TABLE>
Hmmm, then why does it say "flywheel" on the side of the chart?
Old Feb 18, 2006 | 08:49 PM
cobra2326's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, then why does it say "flywheel" on the side of the chart?</TD></TR></TABLE>
Jeff Evans uses a dynapack chassis dyno. Also, those numbers were @ 6psi. Assuming a 15% drivetrain loss, that gives us 156 torque. At 8 psi, this number would be right around 175tq. So even if those were flywheel numbers, you just proved that we proved you wrong. Also, that was on a straight t3. A t3/t4 hybrid will produce more power at 6psi, a 2.5" dp and 2.5" exhaust will also produce more power.
Go and check out evans-tuning.com and see exactly how easy it is to make this kids goals on 8psi...
Old Feb 18, 2006 | 09:05 PM
BLKEG6T's Avatar
oh yeah my dyno numbers last year were consistintly 170whp/125wtq. i have a very strong motor
bummax
Feb 4, 2008 09:10 PM
blinx9900
Nov 9, 2007 05:29 PM
DeadVet
Jul 6, 2005 07:33 PM
JM Performance
Jan 1, 2004 03:13 PM
JM Performance
Nov 16, 2003 04:39 AM
